Hughes SOLID cam users
#563734
12/27/09 04:56 AM
12/27/09 04:56 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Post your results / experiences if you have used a SOLID , flat tappet Hughes camshaft . Im looking at either the 6872BS3 or the 6468BS3 . i will be using a 1.6 rocker and Isky 400lbs open springs
Re: Hughes SOLID cam users
[Re: S/ST 3040]
#563738
12/27/09 03:33 PM
12/27/09 03:33 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Have the HE6064AS in 360 in 71 Dart with eddy heads, ran a best of 11.03 at 121 in Vegas.
Looking for solid cam for 408 with eddy heads for same car...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 493_DART]
#563739
12/27/09 03:41 PM
12/27/09 03:41 PM
Posts: 2,119 sc
tjmarcus1
sc
i have run that exact 268/272. the one i run now is bigger. break it in properly and don't let it idle excessively. highly recommended!!!!
[Re: 493_DART]
#563742
12/27/09 05:43 PM
12/27/09 05:43 PM
Posts: 2,119 sc
tjmarcus1
sc
no big block guys ?
my bad. the 268/272 i ran was a big block.
[Re: nss guy]
#563744
12/27/09 07:06 PM
12/27/09 07:06 PM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
I run the HTL6872BS in my 383/496, in my 3400 pound 70 Dart have gone 10.22 @127, 1.40 60 ft, [Email]6.45@106.89[/Email] mph 1/8th. Have all of their valve train parts, roller rockers, shafts and hold down kit, push rods,Pro-gear timing chain and stud girdle kit. Have had no problems and excellent customer service. ...Matt
[Re: Wicked49670dart]
#563749
12/27/09 11:52 PM
12/27/09 11:52 PM
493_DART
Worst Weather USA
sounds good - whats your cr and heads?
obviously I will call Hughes with my combo - just wondering and shopping at this time
[Re: 493_DART]
#563751
12/28/09 01:21 PM
12/28/09 01:21 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
Is your engine assembled and you want to make a cam change or is it apart ? If it's assembled then an HTL is not a good idea unless your lifter geometry is absolutely spot on and/or your lifter bores are bushed .
