Hughes SOLID cam users #563734
12/27/09 04:56 AM
12/27/09 04:56 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Post your results / experiences if you have used a SOLID , flat tappet Hughes camshaft .
Im looking at either the 6872BS3 or the 6468BS3 .
i will be using a 1.6 rocker and Isky 400lbs open springs
Re: Hughes SOLID cam users [Re: 493_DART] #563735
12/27/09 05:47 AM
12/27/09 05:47 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
bump
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Hughes SOLID cam users [Re: 493_DART] #563736
12/27/09 08:27 AM
12/27/09 08:27 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm running their 6064AS in my 408 with the EDM lifters they sell. With no tuning it has ran 6.61 (1/8) in a 3300# 69 Dart on pump 93. This is the second cam I've had from them and both have ran strong. The first was a hydraulic in my 340, it ran 7.23 in the same car.
Re: Hughes SOLID cam users [Re: 493_DART] #563737
12/27/09 10:13 AM
12/27/09 10:13 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I ran an older HEV6876AS in my 340 with iron heads.
I picked the wrong grind. Went 10.74 @ 124.73 MPH
Re: Hughes SOLID cam users [Re: S/ST 3040] #563738
12/27/09 03:33 PM
12/27/09 03:33 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Have the HE6064AS in 360 in 71 Dart with eddy heads, ran a best of 11.03 at 121 in Vegas.
Looking for solid cam for 408 with eddy heads for same car...
Tony
70 AARCuda Vitamin C
Re: Hughes SOLID cam users [Re: 493_DART] #563739
12/27/09 03:41 PM
12/27/09 03:41 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i have run that exact 268/272. the one i run now is bigger. break it in properly and don't let it idle excessively. highly recommended!!!!
Re: Hughes SOLID cam users [Re: S/ST 3040] #563740
12/27/09 04:52 PM
12/27/09 04:52 PM
Mississippi Gulf Coast
Mroctober Offline
Mroctober  Offline
I got that cam for sale 100.00
Re: Hughes SOLID cam users [Re: Mroctober] #563741
12/27/09 04:56 PM
12/27/09 04:56 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
no big block guys ?
Re: Hughes SOLID cam users [Re: 493_DART] #563742
12/27/09 05:43 PM
12/27/09 05:43 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
no big block guys ?
my bad. the 268/272 i ran was a big block.
Re: Hughes SOLID cam users [Re: tjmarcus1] #563743
12/27/09 06:25 PM
12/27/09 06:25 PM
central ohio
N
nss guy Online happy
nss guy  Online Happy
N
central ohio
I ran the 256/262 in my 440. Great cam, just make sure you use their springs or what they recommend.
Re: Hughes SOLID cam users [Re: nss guy] #563744
12/27/09 07:06 PM
12/27/09 07:06 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I run the HTL6872BS in my 383/496, in my 3400 pound 70 Dart have gone 10.22 @127, 1.40 60 ft, [Email]6.45@106.89[/Email] mph 1/8th. Have all of their valve train parts, roller rockers, shafts and hold down kit, push rods,Pro-gear timing chain and stud girdle kit. Have had no problems and excellent customer service. ...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Hughes SOLID cam users [Re: 493_DART] #563745
12/27/09 07:07 PM
12/27/09 07:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is this an HTL cam ?
Re: Hughes SOLID cam users [Re: JohnRR] #563746
12/27/09 07:10 PM
12/27/09 07:10 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Mine is a HTL
Re: Hughes SOLID cam users [Re: Wicked49670dart] #563747
12/27/09 07:19 PM
12/27/09 07:19 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
internet recommendations for camshafts usually results in disappointment. Cam selection should be based on head flow, compression, trans/converter, gearing, car weight, intended usage, etc. Call a cam grinder and give them all your car specs for a more accurate recommendation.
Re: Hughes SOLID cam users [Re: JohnRR] #563748
12/27/09 09:16 PM
12/27/09 09:16 PM
Mroctober Offline
Mroctober  Offline
This one is HEV6872AS New!!!
Re: Hughes SOLID cam users [Re: Wicked49670dart] #563749
12/27/09 11:52 PM
12/27/09 11:52 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
sounds good - whats your cr and heads?
obviously I will call Hughes with my combo - just wondering and shopping at this time
Re: Hughes SOLID cam users [Re: 493_DART] #563750
12/28/09 12:03 AM
12/28/09 12:03 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
cr is 12.20 to 1 , heads are stage VI 2.14/1.81 standard port size, ported and 77cc chambers.
Re: Hughes SOLID cam users [Re: 493_DART] #563751
12/28/09 01:21 PM
12/28/09 01:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is your engine assembled and you want to make a cam change or is it apart ? If it's assembled then an HTL is not a good idea unless your lifter geometry is absolutely spot on and/or your lifter bores are bushed .
