Any power gain going from gasoline to E85? #559632
12/21/09 09:07 PM
12/21/09 09:07 PM
South Carolina
a408swinger Offline OP
mopar addict
mopar addict
South Carolina
Just wondering if it would be worth the trouble to switch over from gasoline (93 octane) to E85 in a street/strip car with a 418" smallblock. Will E85 make any more power?
Re: Any power gain going from gasoline to E85? [Re: a408swinger] #559633
12/21/09 09:29 PM
12/21/09 09:29 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i bet it would with your car...
although ..is the scamp still running the same motor?
it still should make some more power...fwih.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Any power gain going from gasoline to E85? [Re: a408swinger] #559634
12/21/09 09:34 PM
12/21/09 09:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I cant say for fact but when I switched to E-85 I
went exactly the same ET BUT I havent tuned up the
timing yet to see ... plus for me its CHEAP fuel
and I buy it at my local Meijer so its easy to get
(summer fuel only)
Re: Any power gain going from gasoline to E85? [Re: a408swinger] #559635
12/21/09 09:34 PM
12/21/09 09:34 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
on 6-7 engine i've done it has been a minimum of 10 hp and up to 40 on several
Re: Any power gain going from gasoline to E85? [Re: a408swinger] #559636
12/21/09 10:11 PM
12/21/09 10:11 PM
NC
440Jim Offline
440Jim  Offline
NC
It should make a slight gain, but it depends.
What is your engine/car combo now? What does it run? Is E85 available near you? Do you plan on running it in the winter? Winter mix (70-75% ethanol) should not cause you any detonation issues due to your "low" CR and octane requirement, but it will require a tune-up adjustment (mixture) when you change from 80-85% to winter grade.
Re: Any power gain going from gasoline to E85? [Re: 440Jim] #559637
12/22/09 10:25 PM
12/22/09 10:25 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Has anyone encountered any long term effects of E-85? The new "Flex Fuel" cars mention more maintenance and degrade of the fuel system with the use of E-85 in their owners manuals.
Re: Any power gain going from gasoline to E85? [Re: nss guy] #559638
12/22/09 11:23 PM
12/22/09 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nothing yet but its only been a couple of years now
Re: Any power gain going from gasoline to E85? [Re: nss guy] #559639
12/23/09 12:06 AM
12/23/09 12:06 AM
Locomotion Online content
Locomotion  Online Content
I don't have any experience using any alcohol/ethanol in a race engine. But I have seen several fast alcohol bracket cars, and they run cooler. They also require a much richer air/fuel ratio. I have not heard of anything good from its use in street vehicles and this site backs up some of what I already knew, and offers some more information.
Negative ethanol info.
(Don't mean to turn this into a political thread, just adding to the info pool and people can make their own determinations.)
Re: Any power gain going from gasoline to E85? [Re: 440Jim] #559640
12/23/09 12:09 AM
12/23/09 12:09 AM
South Carolina
mopar addict
mopar addict
South Carolina
The motor is a 9.7 to 1 compression 418 with Indy 360-1 heads, a bullet roller cam, and a 1000 cfm Pro systems carb. Its in a 72 Scamp and runs 6.60's on motor and 5.90's on spray. I mix some 110 with the pump gas when I spray it. Any issues or problems with running E 85 all the time?
Re: Any power gain going from gasoline to E85? [Re: a408swinger] #559641
12/23/09 12:37 AM
12/23/09 12:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The only issue you would have running it all the time
is that using a carb you would need to re -tune it
in the fall and again in the spring for the winter
summer grade fuels... injected cars its done for you
in the computer (larger injector pulse)
Re: Any power gain going from gasoline to E85? [Re: Locomotion] #559642
12/23/09 09:24 AM
12/23/09 09:24 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
The link you posted is propaganda, plain and simple. Further I cant see that it has bearing on us hobbyists or racers. You have to understand there is a HUGE difference between E10 gas and E85. Of course E10 gas is going to cause some problems(Esp in newer outboard engines), the typical passenger car fuel system was not designed for E10. E85 is a completely different animal, when your fuel system is right for it.
FWIW, in regards to your statement of a much richer fuel mixture. Sort of a false statement. FWIW, my street car get about 9-10 MPG on gas, about 7 on E85. FWIW, the 9-10 was with a pig rich carb and 3.23 gears. THe 7 is with a decent tune and 4.30s.
To the OP, you need to find better info, say raceon85.com and go from there.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Any power gain going from gasoline to E85? [Re: Von] #559643
12/23/09 06:00 PM
12/23/09 06:00 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I switched my racecar to E85 last year but I really don't see any benefits of switching a pump gas engine to E85. Its not much cheaper than 93. It is absolutely worth the swap on an engine that is using racing gas at $7 per gallon.
My car runs exactly the same on E85 as 110. If I can just get used to the smell.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Any power gain going from gasoline to E85? [Re: 69dart] #559644
12/23/09 06:40 PM
12/23/09 06:40 PM
Newark, OH
springers340dart Offline
Newark, OH
ahhh the smell is definetly somthing to get used to and dont smell too bad!! haha
Re: Any power gain going from gasoline to E85? [Re: springers340dart] #559645
12/23/09 06:46 PM
12/23/09 06:46 PM
Mid-Ohio
Bakaruda432 Offline
mopar addict
Bakaruda432  Offline
mopar addict
Mid-Ohio
Wouldn't E-85 show a biggier improvement in Boosted engines?
Re: Any power gain going from gasoline to E85? [Re: Bakaruda432] #559646
12/23/09 06:59 PM
12/23/09 06:59 PM
Aubrey, Texas
oldtimer5151 Offline
Happy Birthday oldtimer5151  Offline
Aubrey, Texas
E-85 will run a bit cooler and cost less than race gas. The btu is less than gas so more has to be burnt to equal gasoline. The carb. will have to be opened up.
Re: Any power gain going from gasoline to E85? [Re: a408swinger] #559647
12/23/09 08:12 PM
12/23/09 08:12 PM
sweden
street_dart Offline
street_dart  Offline
sweden
I run my 499 13.7-1 engine on the same dyno same day.
60 more Hp on VP 109 unleded comperd to E-85 from the pump.
And this was full tuned on e-85. We tuned it for two days on e-85. The last thing we did was putting the old gas carb on and pick upp 40 on the first run. After some tuning we pick upp 20 more.
E-85 is not as good as race gas!
Comperd to pump gas I dont know?
Dodge Dart-67 Dodge Custom Royal Lancer-55 Dodge Dakota 4.7 -05
Re: Any power gain going from gasoline to E85? [Re: street_dart] #559648
12/23/09 08:24 PM
12/23/09 08:24 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I agree with this completely.
Re: Any power gain going from gasoline to E85? [Re: a408swinger] #559649
12/24/09 12:15 PM
12/24/09 12:15 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW, on my 511 CID, using runs in comparable weather condition, the E85 was quicker by about a tenth. The torque improvement may be more than the hp improvement, but I just use the timeslip.
110 Gas: 83F, 47%RH, 29,84"Hg, 9.51 at 139 mph
Pump E85: 85, 50%RH, 29.79"Hg, 9.39 at 140 mph (worse conditions than gas)
110 Gas: 83F, 23%RH, 30.11"Hg, 9.43 at 139 mph
Pump E85: 83, 39%RH, 30.06"Hg, 9.34 at 141 mph (worse conditions than gas)
And in cooler weather, the difference will be smaller.
