Re: Any power gain going from gasoline to E85?
[Re: a408swinger]
#559633
12/21/09 09:29 PM
12/21/09 09:29 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i bet it would with your car... although ..is the scamp still running the same motor? it still should make some more power...fwih. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: a408swinger]
#559634
12/21/09 09:34 PM
12/21/09 09:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just wondering if it would be worth the trouble to switch over from gasoline (93 octane) to E85 in a street/strip car with a 418" smallblock. Will E85 make any more power?
I cant say for fact but when I switched to E-85 I went exactly the same ET BUT I havent tuned up the timing yet to see ... plus for me its CHEAP fuel and I buy it at my local Meijer so its easy to get (summer fuel only)
[Re: nss guy]
#559638
12/22/09 11:23 PM
12/22/09 11:23 PM
MR_P_BODY
Has anyone encountered any long term effects of E-85? The new "Flex Fuel" cars mention more maintenance and degrade of the fuel system with the use of E-85 in their owners manuals.
Nothing yet but its only been a couple of years now
[Re: nss guy]
#559639
12/23/09 12:06 AM
12/23/09 12:06 AM
Posts: 5,894 Florida
Locomotion
I don't have any experience using any alcohol/ethanol in a race engine. But I have seen several fast alcohol bracket cars, and they run cooler. They also require a much richer air/fuel ratio. I have not heard of anything good from its use in street vehicles and this site backs up some of what I already knew, and offers some more information.
Negative ethanol info.
(Don't mean to turn this into a political thread, just adding to the info pool and people can make their own determinations.)
[Re: 440Jim]
#559640
12/23/09 12:09 AM
12/23/09 12:09 AM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
It should make a slight gain, but it depends. What is your engine/car combo now? What does it run? Is E85 available near you? Do you plan on running it in the winter? Winter mix (70-75% ethanol) should not cause you any detonation issues due to your "low" CR and octane requirement, but it will require a tune-up adjustment (mixture) when you change from 80-85% to winter grade.
The motor is a 9.7 to 1 compression 418 with Indy 360-1 heads, a bullet roller cam, and a 1000 cfm Pro systems carb. Its in a 72 Scamp and runs 6.60's on motor and 5.90's on spray. I mix some 110 with the pump gas when I spray it. Any issues or problems with running E 85 all the time?
[Re: a408swinger]
#559641
12/23/09 12:37 AM
12/23/09 12:37 AM
MR_P_BODY
The only issue you would have running it all the time is that using a carb you would need to re -tune it in the fall and again in the spring for the winter summer grade fuels... injected cars its done for you in the computer (larger injector pulse)
[Re: Locomotion]
#559642
12/23/09 09:24 AM
12/23/09 09:24 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
The link you posted is propaganda, plain and simple. Further I cant see that it has bearing on us hobbyists or racers. You have to understand there is a HUGE difference between E10 gas and E85. Of course E10 gas is going to cause some problems(Esp in newer outboard engines), the typical passenger car fuel system was not designed for E10. E85 is a completely different animal, when your fuel system is right for it.
FWIW, in regards to your statement of a much richer fuel mixture. Sort of a false statement. FWIW, my street car get about 9-10 MPG on gas, about 7 on E85. FWIW, the 9-10 was with a pig rich carb and 3.23 gears. THe 7 is with a decent tune and 4.30s.
To the OP, you need to find better info, say raceon85.com and go from there.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: 69dart]
#559644
12/23/09 06:40 PM
12/23/09 06:40 PM
Posts: 189 Newark, OH
springers340dart
Newark, OH
If I can just get used to the smell.
ahhh the smell is definetly somthing to get used to and dont smell too bad!! haha
[Re: a408swinger]
#559647
12/23/09 08:12 PM
12/23/09 08:12 PM
Posts: 140 sweden
street_dart
sweden
I run my 499 13.7-1 engine on the same dyno same day. 60 more Hp on VP 109 unleded comperd to E-85 from the pump.
And this was full tuned on e-85. We tuned it for two days on e-85. The last thing we did was putting the old gas carb on and pick upp 40 on the first run. After some tuning we pick upp 20 more.
E-85 is not as good as race gas! Comperd to pump gas I dont know?
Dodge Dart-67
Dodge Custom Royal Lancer-55
Dodge Dakota 4.7 -05
[Re: street_dart]
#559648
12/23/09 08:24 PM
12/23/09 08:24 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I agree with this completely.
[Re: a408swinger]
#559649
12/24/09 12:15 PM
12/24/09 12:15 PM
Posts: 16,930 NC
440Jim
NC
FWIW, on my 511 CID, using runs in comparable weather condition, the E85 was quicker by about a tenth. The torque improvement may be more than the hp improvement, but I just use the timeslip.
110 Gas: 83F, 47%RH, 29,84"Hg, 9.51 at 139 mph Pump E85: 85, 50%RH, 29.79"Hg, 9.39 at 140 mph (worse conditions than gas)
110 Gas: 83F, 23%RH, 30.11"Hg, 9.43 at 139 mph Pump E85: 83, 39%RH, 30.06"Hg, 9.34 at 141 mph (worse conditions than gas)
And in cooler weather, the difference will be smaller.
