Re: B1Bs heads and rocker gear
[Re: 471b1dart]
#554356
12/15/09 02:15 PM
12/15/09 02:15 PM
Posts: 2,273 Greenville, South Carolina
BBLM23
I couldn't find any pics with the valve covers off... I will take one when I get home.
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
[Re: BradH]
#554362
12/15/09 04:53 PM
12/15/09 04:53 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i just got off thge phone with HS and if you have a current set and ordser intakes he could [maybe] give 20% off to make it 46$ea.X8=372$ and change.i was maybe looking at a 1.65 ratio for a little extra intake opening for boost. ps: that was a custom ratio rocker quote.
[Re: Vintage]
#554368
12/16/09 06:20 AM
12/16/09 06:20 AM
Posts: 998 Clinton Township, Michigan
Dartin
I had the original rockers on my BS heads for quite a while without problems.Then I went to a mech roller.That's when the valvetrain nightmares started. I talked to Chuck @ Best Machine he recommended T&D's and I have had no trouble since.I would recommend them to anyone.
What kind of nightmares did you encounter? I've got a set of these heads on a 451 low deck with a roller cam. Just curious what to watch for.
[Re: Cab_Burge]
#554369
12/16/09 07:20 PM
12/16/09 07:20 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
2nd pic
What diameter are those pushrods, if you don't mind saying they don't look like 3/8
I don't remember what size the pushrods are, and I probably won't be pulling the valve covers off untill this spring. They are smith brother push rods.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: 471b1dart]
#554372
12/17/09 07:34 PM
12/17/09 07:34 PM
Posts: 140 sweden
street_dart
sweden
B1-BS Crane gold. .030-.040 space/pair.
Dodge Dart-67
Dodge Custom Royal Lancer-55
Dodge Dakota 4.7 -05
