B1Bs heads and rocker gear #554355
12/15/09 02:04 PM
12/15/09 02:04 PM
Fredericton NB Canada
471b1dart Offline OP
Anyone got any pics of a set of B1Bs heads for a big block with the rockerarms and spacers thanks
Re: B1Bs heads and rocker gear [Re: 471b1dart] #554356
12/15/09 02:15 PM
12/15/09 02:15 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
I couldn't find any pics with the valve covers off... I will take one when I get home.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: B1Bs heads and rocker gear [Re: BBLM23] #554357
12/15/09 02:17 PM
12/15/09 02:17 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Dont know if this helps you much...
Re: B1Bs heads and rocker gear [Re: B1Fish540] #554358
12/15/09 03:33 PM
12/15/09 03:33 PM
Thanks any pics are a help
Re: B1Bs heads and rocker gear [Re: B1Fish540] #554359
12/15/09 04:23 PM
12/15/09 04:23 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i am interested also.scott said i could use my HS rocker on the exh side and the intake was offset more than stock so i needed to have HS make me some with the proper offset.i hope to get a set of BS heads also this winter.thanks for the post.
Re: B1Bs heads and rocker gear [Re: blownzoom440] #554360
12/15/09 04:33 PM
12/15/09 04:33 PM
BBLM23 Offline
BBLM23  Offline
I bought a set of Harland Sharps for the B1/BS heads.
Walter
1981 Reliant 400
Re: B1Bs heads and rocker gear [Re: BBLM23] #554361
12/15/09 04:36 PM
12/15/09 04:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Maybe it's just the angle of the image, but those HS rockers look too long on B1-BS heads to have a properly centered valve sweep. FWIW, they have the same issue on Edelbrock heads, too.
Re: B1Bs heads and rocker gear [Re: BradH] #554362
12/15/09 04:53 PM
12/15/09 04:53 PM
ELYRIA,OH
ELYRIA,OH
i just got off thge phone with HS and if you have a current set and ordser intakes he could [maybe] give 20% off to make it 46$ea.X8=372$ and change.i was maybe looking at a 1.65 ratio for a little extra intake opening for boost.
ps: that was a custom ratio rocker quote.
Re: B1Bs heads and rocker gear [Re: blownzoom440] #554363
12/15/09 08:52 PM
12/15/09 08:52 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Pics
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: B1Bs heads and rocker gear [Re: Dartsport540] #554364
12/15/09 08:53 PM
12/15/09 08:53 PM
Ringtown, Pa.
Ringtown, Pa.
2nd pic
Re: B1Bs heads and rocker gear [Re: Dartsport540] #554365
12/16/09 12:07 AM
12/16/09 12:07 AM
2nd pic
What diameter are those pushrods, if you don't mind saying they don't look like 3/8
Re: B1Bs heads and rocker gear [Re: Cab_Burge] #554366
12/16/09 01:03 AM
12/16/09 01:03 AM
Waterford,NY
V
Vintage Offline
Vintage  Offline
V
Waterford,NY
I had the original rockers on my BS heads for quite a while without problems.Then I went to a mech roller.That's when the valvetrain nightmares started. I talked to Chuck @ Best Machine he recommended T&D's and I have had no trouble since.I would recommend them to anyone.
Re: B1Bs heads and rocker gear [Re: Dartsport540] #554367
12/16/09 02:14 AM
12/16/09 02:14 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks like stock hold downs...........seems awfully risky to me.
Re: B1Bs heads and rocker gear [Re: Vintage] #554368
12/16/09 06:20 AM
12/16/09 06:20 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
What kind of nightmares did you encounter? I've got a set of these heads on a 451 low deck with a roller cam. Just curious what to watch for.
Re: B1Bs heads and rocker gear [Re: Cab_Burge] #554369
12/16/09 07:20 PM
12/16/09 07:20 PM
Ringtown, Pa.
Ringtown, Pa.
2nd pic
I don't remember what size the pushrods are, and I probably won't be pulling the valve covers off untill this spring. They are smith brother push rods.
Re: B1Bs heads and rocker gear [Re: Thumperdart] #554370
12/16/09 07:22 PM
12/16/09 07:22 PM
Ringtown, Pa.
Ringtown, Pa.
If you are talking to me?? The rocker arm set up came with the heads when New. I have been using that set up for 4 years so far. No trouble at all.....
Re: B1Bs heads and rocker gear [Re: Dartsport540] #554371
12/16/09 09:40 PM
12/16/09 09:40 PM
thanks for the pics , mine has solid spacers between the rockers instead of springs ,how much clearance should I have between the spacers and rockers? They came with a set of used heads and Im not sure of the brand. I would post some pics but I cant get them to load. thanks again
Re: B1Bs heads and rocker gear [Re: 471b1dart] #554372
12/17/09 07:34 PM
12/17/09 07:34 PM
sweden
street_dart Offline
street_dart  Offline
sweden
B1-BS Crane gold. .030-.040 space/pair.
Dodge Dart-67 Dodge Custom Royal Lancer-55 Dodge Dakota 4.7 -05
Re: B1Bs heads and rocker gear [Re: 471b1dart] #554373
12/17/09 07:48 PM
12/17/09 07:48 PM
sweden
street_dart Offline
street_dart  Offline
sweden
one more
Re: B1Bs heads and rocker gear [Re: street_dart] #554374
12/17/09 08:08 PM
12/17/09 08:08 PM
ELYRIA,OH
ELYRIA,OH
any1 have a pic of the intake port?i sure hope my headers are ok with those heads.[hooker super comp 2" B body 1969]
