BB remote water pump set-up
#552838
12/13/09 06:35 PM
12/13/09 06:35 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
What company use to make the alum. water manifold in place of stock BB water pump and remote water pump kits?
One day I will have something cool here.
Re: BB remote water pump set-up
[Re: joshking440]
#552842
12/13/09 09:45 PM
12/13/09 09:45 PM
sdaurity
North Cackilacky
Shogun is what I was thinking of. thanks Got a link or pics of Andyf stuff? I think I'm going to use the CSR remote pump.
[Re: sdaurity]
#552846
12/14/09 12:04 PM
12/14/09 12:04 PM
Posts: 31,078 Oregon
AndyF
The manifolds are set up for #12 o-ring fittings. I use #16 AN fittings with #12 o-ring bases but you can get #12 AN to #12 o-ring if you want.
The manifolds are 1.50 inches thick. Part number is AR245 for the kit. Mancini Racing, Hughes Engines, Mayo Performance, Bob Mazzolini Racing, etc. can get it for you.
[Re: bigtimeauto]
#552850
12/14/09 04:20 PM
12/14/09 04:20 PM
AndyF
You can also get fittings from Meziere that convert from o-ring to hose. Some guys prefer to run hose because it is a lot less expensive. You don't really need braided lines for coolant because the pressure is so low.
Andy, I meant does it take the stock gasket on the block side or does that take a oring. I want to get rid of my gaskets and do orings on the motor plate and pump setup. thanks
It uses a stock gasket. Actually I use the water pump gaskets from Cometic. They seem to work the best. There isn't really enough room to put o-rings in there if the water passage is full size.
[Re: slippery440]
#552852
12/14/09 11:15 PM
12/14/09 11:15 PM
AndyF
Part number does not work.
Part number works fine. Price is on the price list on the website. Call one of the dealers and order the part. Mayo, Hughes, Mancini, etc.
[Re: AndyF]
#552853
12/15/09 08:58 AM
12/15/09 08:58 AM
sdaurity
North Cackilacky
Has anybody found out how much this is yet?
Post deleted by Defbob
[Re: sdaurity]
#552854
12/15/09 09:25 AM
12/15/09 09:25 AM
[Re: slippery440]
#552856
12/15/09 10:47 AM
12/15/09 10:47 AM
sdaurity
North Cackilacky
x2 I couldn't find anything on hughes or mancini site.
