BB remote water pump set-up #552838
12/13/09 06:35 PM
12/13/09 06:35 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
What company use to make the alum. water manifold in place of stock BB water pump and remote water pump kits?
One day I will have something cool here.
Re: BB remote water pump set-up [Re: sdaurity] #552839
12/13/09 06:55 PM
12/13/09 06:55 PM
okla.
sam64 Offline
sam64  Offline
okla.
sho gun,i think i have one i'm not going to use i'll look for it.
Re: BB remote water pump set-up [Re: sam64] #552840
12/13/09 07:42 PM
12/13/09 07:42 PM
ky
68roadrunner Offline
ky
yep shogun there original pump was not to good, i don't know about the new one. i used a meziere pump on mine.
Re: BB remote water pump set-up [Re: 68roadrunner] #552841
12/13/09 09:18 PM
12/13/09 09:18 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
AndyF makes everything you need other than the remote pump itself, and his stuff is SWWWEEEETTTTTTT A$$ STUFF!!!!!!!!
Re: BB remote water pump set-up [Re: joshking440] #552842
12/13/09 09:45 PM
12/13/09 09:45 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
Shogun is what I was thinking of. thanks Got a link or pics of Andyf stuff? I think I'm going to use the CSR remote pump.
Re: BB remote water pump set-up [Re: sdaurity] #552843
12/13/09 11:09 PM
12/13/09 11:09 PM
AndyF Offline
AndyF  Offline
I make these manifolds for remote water pumps. The manifolds free up space for a belt drive distributor. Also, with the individual manifolds you can swap the lines top to bottom to turn it into a reverse flow setup if you want.
Re: BB remote water pump set-up [Re: AndyF] #552844
12/13/09 11:51 PM
12/13/09 11:51 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Andy, How thick are they? do you make them with Orings instead of gaskets? I think that might be the answer to my newest issue.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: BB remote water pump set-up [Re: AndyF] #552845
12/14/09 08:55 AM
12/14/09 08:55 AM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
How much? What size are the fittings 16an, I was going to do it all in 12an.
Re: BB remote water pump set-up [Re: sdaurity] #552846
12/14/09 12:04 PM
12/14/09 12:04 PM
AndyF Offline
AndyF  Offline
The manifolds are set up for #12 o-ring fittings. I use #16 AN fittings with #12 o-ring bases but you can get #12 AN to #12 o-ring if you want.
The manifolds are 1.50 inches thick. Part number is AR245 for the kit. Mancini Racing, Hughes Engines, Mayo Performance, Bob Mazzolini Racing, etc. can get it for you.
Re: BB remote water pump set-up [Re: sdaurity] #552847
12/14/09 12:07 PM
12/14/09 12:07 PM
AndyF Offline
AndyF  Offline
You can also get fittings from Meziere that convert from o-ring to hose. Some guys prefer to run hose because it is a lot less expensive. You don't really need braided lines for coolant because the pressure is so low.
Re: BB remote water pump set-up [Re: AndyF] #552848
12/14/09 01:40 PM
12/14/09 01:40 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Andy, I meant does it take the stock gasket on the block side or does that take a oring. I want to get rid of my gaskets and do orings on the motor plate and pump setup. thanks
Re: BB remote water pump set-up [Re: bigtimeauto] #552849
12/14/09 02:07 PM
12/14/09 02:07 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Part number does not work.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: BB remote water pump set-up [Re: bigtimeauto] #552850
12/14/09 04:20 PM
12/14/09 04:20 PM
AndyF Offline
AndyF  Offline
It uses a stock gasket. Actually I use the water pump gaskets from Cometic. They seem to work the best. There isn't really enough room to put o-rings in there if the water passage is full size.
Re: BB remote water pump set-up [Re: slippery440] #552851
12/14/09 10:13 PM
12/14/09 10:13 PM
springfield,il
O
orangeduster Offline
O
springfield,il
X2 WOULD LOVE TO ORDER BUT CANT FIND
Re: BB remote water pump set-up [Re: slippery440] #552852
12/14/09 11:15 PM
12/14/09 11:15 PM
AndyF Offline
AndyF  Offline
Part number works fine. Price is on the price list on the website. Call one of the dealers and order the part. Mayo, Hughes, Mancini, etc.
Re: BB remote water pump set-up [Re: AndyF] #552853
12/15/09 08:58 AM
12/15/09 08:58 AM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
Has anybody found out how much this is yet?
Post deleted by Defbob [Re: sdaurity] #552854
12/15/09 09:25 AM
12/15/09 09:25 AM
Re: BB remote water pump set-up #552855
12/15/09 09:43 AM
12/15/09 09:43 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Thanks Hemifred for the parts numbers and prices and a web site to buy from.You would of thought that mabe the guy that makes these would of done that so at least 2 of us that have internet disabilites could find out the price.
Re: BB remote water pump set-up [Re: slippery440] #552856
12/15/09 10:47 AM
12/15/09 10:47 AM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
x2 I couldn't find anything on hughes or mancini site.
Re: BB remote water pump set-up [Re: slippery440] #552857
12/15/09 11:41 AM
12/15/09 11:41 AM
sg66mopar Offline
sg66mopar  Offline
Being a mfg. and selling to dealers Andy has to be unbiased and careful not to step on toes. He's just trying to be fair to his dealer network. Most ethical manufacturers that do not sell direct to the public operate this way.
