Post deleted by Defbob
#549851
12/09/09 07:53 PM
12/09/09 07:53 PM
Re: How high will a scoop need to be to cover these carbs
#549852
12/09/09 08:04 PM
12/09/09 08:04 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
13.654782" inches..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#549853
12/09/09 08:16 PM
12/09/09 08:16 PM
[Re: roadhazard]
#549858
12/09/09 10:16 PM
12/09/09 10:16 PM
[Re: proshiftcharger]
#549863
12/09/09 11:13 PM
12/09/09 11:13 PM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
Fred, Heres a pic with the new scoop on the car. Again you really need measurements but this gives you an idea how big we had to go to make it work. Based on your pics/heighth Im guessing its pretty close to what we have shown here...roughly. Doug
#549864
12/10/09 06:31 AM
12/10/09 06:31 AM
#549865
12/10/09 06:38 AM
12/10/09 06:38 AM
#549866
12/10/09 06:56 AM
12/10/09 06:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The string from the roof line to the front of the hood holds true, now put the bottom of the inlet of the scoop at or above the string... try to use a ideal/ stackon the carb for a better entry into the carb, that will give you a idea on how tall it should be. My carb is about 1.3" below the bottom of the inlet
