Post deleted by Defbob #549851
12/09/09 07:53 PM
12/09/09 07:53 PM
Anonymous OP
Anonymous OP
Re: How high will a scoop need to be to cover these carbs #549852
12/09/09 08:04 PM
12/09/09 08:04 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
13.654782" inches..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Post deleted by Defbob [Re: cheapstreetdustr] #549853
12/09/09 08:16 PM
12/09/09 08:16 PM
Anonymous OP
Anonymous OP
Re: How high will a scoop need to be to cover these carbs #549854
12/09/09 08:45 PM
12/09/09 08:45 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
from my carb base to top of vent tube is 6"[1250's holley]
Re: How high will a scoop need to be to cover these carbs #549855
12/09/09 08:50 PM
12/09/09 08:50 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What scoop you been looking at Fred? Traditional Harwood style Aero scoop, or what you see on the Pro stock cars now?
Re: How high will a scoop need to be to cover these carbs [Re: Bob_Coomer] #549856
12/09/09 09:37 PM
12/09/09 09:37 PM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
I can't recall where I heard this and I'm not sure it holds true for all situations....
If you run a string from the top of the windshield to the leading edge of the hood/header panel, the opening (on pro-style scoops) should be outside the string line.
Of course, not all carbs sit at the same height inside the scoop, so proper internal ducting would be required.
Maybe a chassis shop like RJ, or Bickle can share some of their aero info.
Re: How high will a scoop need to be to cover these carbs #549857
12/09/09 10:13 PM
12/09/09 10:13 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You running an air filter?
cheapstrt..
Post deleted by Defbob [Re: roadhazard] #549858
12/09/09 10:16 PM
12/09/09 10:16 PM
Anonymous OP
Anonymous OP
Re: How high will a scoop need to be to cover these carbs #549859
12/09/09 10:24 PM
12/09/09 10:24 PM
Fred you goin old school or new school on that car.?
it looks pretty low..actually considering its a hemi with tunnel ram...
i think a legitimate 8" is where youll end up..
you need room ontop obviously...but you knew that....
my vote is something traditional...(you might call that ol school..?)
cheapst
http://rides.webshots.com/photo/2183573310082607023wdJJvI
http://rides.webshots.com/photo/2168922160082607023sworHQ
or Honestly i love the ol plexiglass hood treatment. (and the leaf work for that matter)
http://rides.webshots.com/photo/2646540700082607023fbtRjQ
[image][/image]
Re: How high will a scoop need to be to cover these carbs [Re: cheapstreetdustr] #549860
12/09/09 10:57 PM
12/09/09 10:57 PM
[image][/image]
Re: How high will a scoop need to be to cover these carbs #549861
12/09/09 11:07 PM
12/09/09 11:07 PM
Pennsylvania
proshiftcharger Offline
Pennsylvania
Fred,
I know this probably wont help you much because you need actual measurements. But before we made the HEMI swap this had a B-1 motor in it with a single 4. Obviously when making the swap the original scoop wasnt big enough so a bigger Pro Stock style Harwood was bought.
Heres a pic without the hood. You can see the correlation between the carb heighth & the windshield.
Re: How high will a scoop need to be to cover these carbs [Re: proshiftcharger] #549862
12/09/09 11:11 PM
12/09/09 11:11 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
You could try something like the 9" cowl from VFN - or was it 11" ?
Re: How high will a scoop need to be to cover these carbs [Re: proshiftcharger] #549863
12/09/09 11:13 PM
12/09/09 11:13 PM
Pennsylvania
Pennsylvania
Fred,
Heres a pic with the new scoop on the car.
Again you really need measurements but this gives you an idea how big we had to go to make it work. Based on your pics/heighth Im guessing its pretty close to what we have shown here...roughly.
Doug
Post deleted by Defbob [Re: proshiftcharger] #549864
12/10/09 06:31 AM
12/10/09 06:31 AM
Anonymous OP
Anonymous OP
Post deleted by Defbob #549865
12/10/09 06:38 AM
12/10/09 06:38 AM
Anonymous OP
Anonymous OP
Re: How high will a scoop need to be to cover these carbs #549866
12/10/09 06:56 AM
12/10/09 06:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The string from the roof line to the front of the
hood holds true, now put the bottom of the inlet of the
scoop at or above the string... try to use a ideal/
stackon the carb for a better entry into the carb,
that will give you a idea on how tall it should be.
My carb is about 1.3" below the bottom of the inlet
