Duster tail light lens paint? #546834
12/06/09 09:52 AM
12/06/09 09:52 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
Anyone know what type of paint (black) was used on the Duster tail light lenses to black them out where needed? Mine were a little worn so I'm taping them off and repainting them. But I'd like to get as close to the org. paint as possible.
Re: Duster tail light lens paint? [Re: bigblock340power] #546835
12/06/09 12:19 PM
12/06/09 12:19 PM
Renton, Washington
Bobster Offline
Bobster  Offline
Renton, Washington
I'm currently restoring the taillight panel on my 73 Challenger and I used SEM Trim Paint for the flat black portions of it. It has a really good finish and applies easily.
Re: Duster tail light lens paint? [Re: bigblock340power] #546836
12/06/09 07:38 PM
12/06/09 07:38 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...originally they were just the color of the plastic and injection molded or whatever,so you'll have to fudge it.
you can probably get it pretty close with some of the rattle can trim paints in a low lustre black..
.al
Re: Duster tail light lens paint? [Re: can.al] #546837
12/06/09 10:31 PM
12/06/09 10:31 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I have seen several NOS 70/71 Duster taillight lenses and the black part looked glossy to me (not flat or satin finish).
Re: Duster tail light lens paint? [Re: pinkduster] #546838
12/06/09 10:34 PM
12/06/09 10:34 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Correct. I used a semi-gloss on mine.
Re: Duster tail light lens paint? [Re: bigblock340power] #546839
12/07/09 12:03 AM
12/07/09 12:03 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
you might be able to get back to the original finish by wet sanding with 1200 and then
polishing, there should be some 'lustre.
Re: Duster tail light lens paint? [Re: can.al] #546840
12/07/09 12:07 AM
12/07/09 12:07 AM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
If you sand them, there won't be any black paint left.
Re: Duster tail light lens paint? [Re: Steve340] #546841
12/07/09 10:33 AM
12/07/09 10:33 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Thought it was black plastic?
Re: Duster tail light lens paint? [Re: buildanother] #546842
12/08/09 07:53 PM
12/08/09 07:53 PM
Elk Grove, Calif.
Elk Grove, Calif.
No, they are not black plastic. I've taken whats left of the black off to repaint them. I have two sets of lenses so I can reference the other set for accuracy.
Re: Duster tail light lens paint? [Re: bigblock340power] #546843
12/08/09 08:38 PM
12/08/09 08:38 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
They should be gloss black, maybe one of the new plastic fusion paints from Krylon or someone? I used semi gloss on mine and don't forget the new tail light gaskets
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Duster tail light lens paint? [Re: 340wedge] #546844
12/08/09 08:44 PM
12/08/09 08:44 PM
Elk Grove, Calif.
Elk Grove, Calif.
I'll look into the Krylon paints. I bought the gasket set long ago. I'm set in that area.
Re: Duster tail light lens paint? [Re: bigblock340power] #546845
12/09/09 10:04 PM
12/09/09 10:04 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Sounds like you got the black covered, so I'll add a little tip I have used many times on taillite lenses. Clean and glassbead the lenses, then have them clear-coated. They look like new and it should help the black adhere a little better.
Master, again and still
