Re: Duster tail light lens paint?
[Re: buildanother]
#546842
12/08/09 07:53 PM
12/08/09 07:53 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Thought it was black plastic?
No, they are not black plastic. I've taken whats left of the black off to repaint them. I have two sets of lenses so I can reference the other set for accuracy.
[Re: 340wedge]
#546844
12/08/09 08:44 PM
12/08/09 08:44 PM
bigblock340power
Elk Grove, Calif.
They should be gloss black, maybe one of the new plastic fusion paints from Krylon or someone? I used semi gloss on mine and don't forget the new tail light gaskets
I'll look into the Krylon paints. I bought the gasket set long ago. I'm set in that area.
[Re: bigblock340power]
#546845
12/09/09 10:04 PM
12/09/09 10:04 PM
Posts: 12,078 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Sounds like you got the black covered, so I'll add a little tip I have used many times on taillite lenses. Clean and glassbead the lenses, then have them clear-coated. They look like new and it should help the black adhere a little better.
Master, again and still
