Page 1 of 3 1 2 3
Duster Carnage Pics..... Makes me sick....340 4 speed #537773
11/27/09 12:09 AM
11/27/09 12:09 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Duster Carnage Pics..... Makes me sick.... [Re: DemonDust] #537774
11/27/09 12:14 AM
11/27/09 12:14 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
OUCH!
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Duster Carnage Pics..... Makes me sick.... [Re: DemonDust] #537775
11/27/09 12:14 AM
11/27/09 12:14 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Aww man, that sucks. Looks like all kinds of big dollar mess going on in the photos. What do you think started the chain reaction of breakage?
Re: Duster Carnage Pics..... Makes me sick.... [Re: ProSport] #537776
11/27/09 12:19 AM
11/27/09 12:19 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
driveshaft
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Duster Carnage Pics..... Makes me sick.... [Re: ProSport] #537777
11/27/09 12:21 AM
11/27/09 12:21 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
WOW hate to see that.
Lots of RPM's?
Good thing that stock bellhousing held together.
Re: Duster Carnage Pics..... Makes me sick.... [Re: bigtimeauto] #537778
11/27/09 12:22 AM
11/27/09 12:22 AM
Menomonee Falls
Menomonee Falls
I'm not really sure. It was the first time spraying the 340. It had a 200 shot. When I shifted from second to third this happened when I let the clutch out. My initial thought was the mechanism screwed up and got stuck in between 2nd and 3rd gear, and it was a chain reaction from there....
SDG Motorsports
Re: Duster Carnage Pics..... Makes me sick.... [Re: DemonDust] #537779
11/27/09 12:34 AM
11/27/09 12:34 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
At least it was not the R5 block!
Re: Duster Carnage Pics..... Makes me sick.... [Re: DemonDust] #537780
11/27/09 12:34 AM
11/27/09 12:34 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Holy hog stools !
Had a similar event in a '66 Cyclone at Brainerd years back.
Had a stock shaft balanced and new joints behind a C-6 and a fair 429.
On street tires , it spun through 150 feet or so and when it hooked , it twisted the shaft in half........shelling the tailshaft and oiling the lane for half the track.
Since we were in the third pair in the first time trial session , so you could say that we made no friends that morning.
My better half was driving and she got it over to the rail like you are supposed to do , but it was a long clean up.
I was on the line and when the trans fluid hit the headers , it was white out time.........I didn't know if she was on the wheels or the roof.
But I definitely feel your pain.
Well , maybe not.
Even in 1990 dollars , yours would probably cost more.
Could have been worse , but still , condolences.
Re: Duster Carnage Pics..... Makes me sick.... [Re: DemonDust] #537781
11/27/09 12:35 AM
11/27/09 12:35 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I've twisted off a few drive shafts like that ,but never broke all the rest including the motor . Sorry for your loss.
Re: Duster Carnage Pics..... Makes me sick.... [Re: Dos Snails] #537782
11/27/09 12:42 AM
11/27/09 12:42 AM
Menomonee Falls
Menomonee Falls
yes, good point, just so everyone knows this is not my white duster....
So it sounds more like the driveshaft broke first?
SDG Motorsports
Re: Duster Carnage Pics..... Makes me sick.... [Re: DemonDust] #537783
11/27/09 12:53 AM
11/27/09 12:53 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
wow !!
sorry to see it man....
but you must be making some serious power !!!
Re: Duster Carnage Pics..... Makes me sick.... [Re: 493_DART] #537784
11/27/09 01:06 AM
11/27/09 01:06 AM
Menomonee Falls
Menomonee Falls
I wouldn't call it serious. With a 200 shot of nitrous I figure it might have been making 650ish?
Just a set of x heads with max porting, 2.02 valves, M1 intake, on a 340 10.5:1, mopar forged crank, eagle rods. It was a budget build at the time.
I don't remember the cam specs off hand, it was comp cam custom ground.
.528 IN
.534 EX
307 Adv duration
114 centerline installed at 110
IIRC... It's been quite a few years since I built this engine.
SDG Motorsports
Re: Duster Carnage Pics..... Makes me sick.... [Re: DemonDust] #537785
11/27/09 01:56 AM
11/27/09 01:56 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
That SUCKS, It even makes me feel sick.
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: DemonDust] #537786
11/27/09 02:28 AM
11/27/09 02:28 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Wow that is alot of damage, the way the shaft looks is it possible something in the rear end started this, maybe a broken perch. Either way sorry for your loss.
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: 68Fastback] #537787
11/27/09 03:23 AM
11/27/09 03:23 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Looks like the shaft broke and started the chain reaction. Should be able to fix the block. What does the floor of the car look like?
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: DemonDust] #537788
11/27/09 03:33 AM
11/27/09 03:33 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Was that a numbers matching drive train that just got grenaded?
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: ScottSmith_Harms] #537789
11/27/09 03:52 AM
11/27/09 03:52 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'd have to assume that something locked up in the trans ro spin it on the bellhousing and break the ears like that. I'll be interested to see what the inside looks like. Bummer!
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: Jeremiah] #537790
11/27/09 04:24 AM
11/27/09 04:24 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
It looks like the trans got jammed up by going into both 2 and 3 gears (there is a lockout on the housing that is "suposeto" prevent this). With the extra power it just did not break loose, A broken fork (between the 1-2) may have cause it not to get out of gear.
Once the trans locked up hard, the weight of the car and the momentum, just twisted the entire engine / tras until something had to give; unfortunately the parts were so equal, a lot gave...
Look at the direction of the twist on the drive shaft, I bet it is not clockwise (going forward) it is ccw (because the wheels were driving against a stopped load)
Be careful taking the tras apart and do some good careful looking to get to the root cause, but that is crazy...
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: 6T6Cuda] #537791
11/27/09 06:26 AM
11/27/09 06:26 AM
gregsdart Offline
gregsdart  Offline
Sorry for the loss, I agree looks like the tranny locked up, and kept breaking stuff till there was no connection to torque input from either end.
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: gregsdart] #537792
11/27/09 08:56 AM
11/27/09 08:56 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
That looks bad.
18 mths ago, my driveshaft let go going through the 1/4 finish line at 120 mph, smashed the trans case all the way round, and beat the hell out of the floor.
This year at the same meet, i over revved it and put a piston through the block
Mick
Page 1 of 3 1 2 3
