Re: e-body fuel capacity?
[Re: Snoopy]
#531609
11/20/09 03:02 PM
11/20/09 03:02 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
The reproduction tanks hold 19 gals. They don't have the 1 gallon expansion tank inside.
Interesting to know. I have a re-pop tank on my Challenger, although I don't plan on running it down to that last "extra" gallon...
[Re: aar1]
#531612
11/21/09 09:50 PM
11/21/09 09:50 PM
Posts: 823 On the open road
Hrtbkr
On the open road
The tank may hold 18 or 19 gallons, but my car (with a repop sender/pickup) quits running at about 16.5 gallons. DAMHIK
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: aar1]
#531613
11/21/09 10:41 PM
11/21/09 10:41 PM
Posts: 186 Southern California
Robert1050
stuck in da 70s
stuck in da 70s
Southern California
It had maybe 30 minutes of idle time on that tank and only 125 miles! Does that sound right? Less than 7 mpg!!
Wow, you're doing pretty good at that. My old '70 440-6 'cuda (with super-track pack) used to go maybe 100 miles on a tank of gas, which worked out to about 4-5MPG on the street and maybe 6MPG on the highway.
[Re: Robert1050]
#531614
11/22/09 01:45 PM
11/22/09 01:45 PM
Posts: 788 middle of the country
aar1
But with 355 gears & a 4bbl.... shouldn't I be able to do a bit better than 7mpg? The car doesn't get driven much so it's not so much the cost of filling up but the lack of range I will get with the car.
I just filled the car up from empty (engine quite). It took 17.2 gallons. That's up to the filler neck.
[Re: aar1]
#531615
11/22/09 01:55 PM
11/22/09 01:55 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Another alternative is a 2 bbl and/or lighter shoes! Seriously though, short trips use up more gas that one long one too. Just a thought (Edit: Srry Greetween. Missed your comment about short trips...)
[Re: Scott Carl]
#531616
11/22/09 08:45 PM
11/22/09 08:45 PM
aar1
You know what they say about guys who have big feet .............. they require heavy shoes.
[Re: aar1]
#531617
11/23/09 01:51 AM
11/23/09 01:51 AM
Posts: 2,112 New Jersey, US of A
PlumCrazy73Dodge
New Jersey, US of A
440 = Go Fast Gas
and
Gas go Fast
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
