e-body fuel capacity? #531603
11/20/09 08:19 AM
11/20/09 08:19 AM
middle of the country
aar1 Offline OP
aar1  Offline OP
Can someone please tell me what the fuel capacity is for a 1970 Barracuda? Thanks.
"not enough" is not an acceptable answer
Re: e-body fuel capacity? [Re: aar1] #531604
11/20/09 08:29 AM
11/20/09 08:29 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Either 18 or 19
Re: e-body fuel capacity? [Re: Mopar-Al] #531605
11/20/09 08:34 AM
11/20/09 08:34 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yup. and don't trust the factory gauge either. when mine hit empty, it always took only 12 gallons to fill up. still, knowing this, I could never bring myself to keep driving once that needle was pointing at "E"!!!
**Photobucket sucks**
Re: e-body fuel capacity? [Re: aar1] #531606
11/20/09 10:31 AM
11/20/09 10:31 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
The factory "stated" fuel capacity on all E-bodies from 70-74 is 18 gallons...
Re: e-body fuel capacity? [Re: 318 Stroker] #531607
11/20/09 01:30 PM
11/20/09 01:30 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
yes,57 liter.after that you,ll walk
Re: e-body fuel capacity? [Re: cuda-sweden] #531608
11/20/09 02:55 PM
11/20/09 02:55 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The reproduction tanks hold 19 gals. They don't have the 1 gallon expansion tank inside.
Re: e-body fuel capacity? [Re: Snoopy] #531609
11/20/09 03:02 PM
11/20/09 03:02 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Interesting to know. I have a re-pop tank on my Challenger, although I don't plan on running it down to that last "extra" gallon...
Re: e-body fuel capacity? [Re: 318 Stroker] #531610
11/21/09 08:08 AM
11/21/09 08:08 AM
aar1 Offline OP
aar1  Offline OP
The reason I was asking is because I just finished up my car after several years and this fall has been the first time I’ve really driven it. It is a 440 4bbl cuda. I have only been thru one tank of gas. I just couldn’t believe the gas gauge and assumed the sending unit was off since the gauges have all been gone thru. Well, the gas gauge wasn’t too far off. Once it hit empty, it ran out within 20 miles or so. It had maybe 30 minutes of idle time on that tank and only 125 miles! Does that sound right? Less than 7 mpg!! Hopefully once it’s broke in, and maybe some carb adjustments, it will get better? This will sure limit me on how far away from home I will want to take it………
Re: e-body fuel capacity? [Re: aar1] #531611
11/21/09 08:43 PM
11/21/09 08:43 PM
ILL
Greentween Offline
Greentween  Offline
ILL
gas evaporates out of the carb when you turn it off hot. So if you made alot of short trips, then 7MPG may be all you get.
Re: e-body fuel capacity? [Re: aar1] #531612
11/21/09 09:50 PM
11/21/09 09:50 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
The tank may hold 18 or 19 gallons, but my car (with a repop sender/pickup) quits running at about 16.5 gallons. DAMHIK
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: e-body fuel capacity? [Re: aar1] #531613
11/21/09 10:41 PM
11/21/09 10:41 PM
Southern California
Robert1050 Offline
stuck in da 70s
Robert1050  Offline
stuck in da 70s
Southern California
Wow, you're doing pretty good at that. My old '70 440-6 'cuda (with super-track pack) used to go maybe 100 miles on a tank of gas, which worked out to about 4-5MPG on the street and maybe 6MPG on the highway.
Re: e-body fuel capacity? [Re: Robert1050] #531614
11/22/09 01:45 PM
11/22/09 01:45 PM
aar1 Offline OP
aar1  Offline OP
But with 355 gears & a 4bbl.... shouldn't I be able to do a bit better than 7mpg? The car doesn't get driven much so it's not so much the cost of filling up but the lack of range I will get with the car.
I just filled the car up from empty (engine quite). It took 17.2 gallons. That's up to the filler neck.
Re: e-body fuel capacity? [Re: aar1] #531615
11/22/09 01:55 PM
11/22/09 01:55 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Another alternative is a 2 bbl and/or lighter shoes! Seriously though, short trips use up more gas that one long one too. Just a thought
(Edit: Srry Greetween. Missed your comment about short trips...)
Re: e-body fuel capacity? [Re: Scott Carl] #531616
11/22/09 08:45 PM
11/22/09 08:45 PM
aar1 Offline OP
aar1  Offline OP
You know what they say about guys who have big feet .............. they require heavy shoes.
Re: e-body fuel capacity? [Re: aar1] #531617
11/23/09 01:51 AM
11/23/09 01:51 AM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
440 = Go Fast Gas
and
Gas go Fast
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
