what cam would you use? #528570
11/16/09 09:59 PM
11/16/09 09:59 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
iv'e sent my specs to comp and lunati no replys so i'll ask those here,combo is 500" indy 440-1 otb 12to1 comp,indy single plane 4150 flange,4500 stall power-gide,4.56 gear,14x32 m/ts,3000lbs race wt,would like to stay around 7200 max rpm,1.5 rockers.this is a foot-brake car.thanks,sam.i have 1000cfm hp or 1050 dom for carbs. forgot looking at solid flat tappet.
Re: what cam would you use? [Re: sam64] #528571
11/16/09 10:26 PM
11/16/09 10:26 PM
SoCal
Brian Hafliger Offline
SoCal
267/274 @.050 .617/.612 w/1.5 ratio on a 110lca advanced 5°. That's what I would run....
Brian Hafliger
Re: what cam would you use? [Re: sam64] #528572
11/16/09 11:20 PM
11/16/09 11:20 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW (just another opinion to throw into the mix), I'd try something like this, only ground on 110 LSA and installed on 106 ICL.
EDIT: On second thought, given the 2-speed trans, it might actually work better w/ the 108 LSA that linked cam is on.
Re: what cam would you use? [Re: sam64] #528573
11/16/09 11:56 PM
11/16/09 11:56 PM
the smallest i'd even consider would be a mid to high 270's@.05 also, put the dominator on it.
Re: what cam would you use? #528574
11/17/09 12:28 AM
11/17/09 12:28 AM
SoCal
SoCal
I missed the otb comment...if your not porting them at all then yeah, I'd run 276/280 @.050 still on a 110lca though.
Are the heads untouched?
Brian Hafliger
Re: what cam would you use? [Re: Brian Hafliger] #528575
11/17/09 12:57 AM
11/17/09 12:57 AM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
...so that .650 McCandless Special was a little too much in my 500 -1 OOTB stroker with a 4500?....what ya got in plan for my new bullet?
Re: what cam would you use? [Re: Chassisman] #528576
11/17/09 02:58 AM
11/17/09 02:58 AM
SoCal
SoCal
It all depends on what you let me get away with power wise...!!
More power, how's that!
Brian Hafliger
Re: what cam would you use? [Re: sam64] #528577
11/17/09 03:45 AM
11/17/09 03:45 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Racer Brown STX-22. 276-276 dur and .590-.590 lift. 106sep and in at 102*
Would be even better with 1.6 RAR. I know a 2500lb Vette with a 500" Indy -1 headed BB Mopar that has gone 8.50s with the smaller STX-21 272x.560 with 1.5 rockers. The STX-22 with 1.6 RAR in my 418c.i. production headed sb mopar has gone 9.68 at 135+ at 3050lbs. Must mention the one in my Demon was bought off eBay for $50 never used and was made in 1970. They are still making them the same. Call Jim at Racer Brown. 410-866-7660
Re: what cam would you use? [Re: Brian Hafliger] #528578
11/17/09 04:02 AM
11/17/09 04:02 AM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Well I'm diggin the pump gas route.....
Re: what cam would you use? [Re: Chassisman] #528579
11/17/09 10:57 AM
11/17/09 10:57 AM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
nick at compu-flow checked them over a corrected valve sealing issues,also up graded retainers and springs to match the comp cam he speced,it lasted 2 passes,4 wiped lobes.so new block,pistons,all machine work and ready to try this again,i have the power-glide now ,727 before.thanks for the info guys.
Re: what cam would you use? [Re: sam64] #528580
11/17/09 02:24 PM
11/17/09 02:24 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
Sam, here's the Scott Brown solid I'm using:
.648/.640 274/280 112 lobe sep, 108 intake centerline
Here are the specs on 440Jim's Scott Brown cam that got him in the mid 9s
.623/.600 272/280 112 lobe sep
Here are the specs on 440Jim's Comp cam that he's running now: MM-305S-10
.650/.650 279/287 110 lobe sep
Here's that big Ray Barton that I have if your interested (only has 25 passes on it, with lifters, already broken in but may be a little big):
.639/.640 283/284 108 lob sep, 104 int centerline
I'd also recommend using the newer lifters with the EDM hole in them to provide some extra insurance against lobes going flat. I got mine from Hughes, I know Jim runs EDM lifters as well.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: what cam would you use? [Re: sam64] #528581
11/17/09 02:34 PM
11/17/09 02:34 PM
gregsdart Offline
gregsdart  Offline
If you loosen the converter to 5500 plus rpm, you can go a lot bigger than you might think. I just found an old time slip that showed my car with a 499 lowdeck, 440-1 with bowl porting only, alky injected 12.5/1 compression at 3000Lbs went 143.3 mph, 9.340 with a horrible 1.366 60 ft. I had an ultrdyne roller in it, 283 @ .050 int, 290 @ .050 exh, 108 lsa . Corrected altitude for that run was 1650 ft. Shifting at 6800 rpm.
Re: what cam would you use? [Re: WadeMetzinger] #528582
11/17/09 02:39 PM
11/17/09 02:39 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
thanks wade,i was going to call you to see what specs were on yours.i just would like to be around 10.0 like your car.i'm guessing racer brown and scott brown are the same place?
Re: what cam would you use? [Re: sam64] #528583
11/17/09 02:51 PM
11/17/09 02:51 PM
Tulsa, Ok
Tulsa, Ok
Nope, Racer Brown is "old School" been around for many years and I don't mean any disrespect by the "old school" comment. His cams are very proven and many guys love his cam profiles. I've never ran one but I've heard a lot of people speak highly of them.
Scott Brown is Straight Line Performance:
http://www.buyracingparts.com/
He's a younger guy, and very very well respected cam spec and builder for a lot of people here on Moparts. A year or so ago that's about all any one was running. He's a mopar guys and has a lot of knowledge on Mopars. Here is his number (616-499-6223) , you can tell him about your car and motor and he will send you his recommendation for a cam. I've ran about 4 of his cams, great guy, great personal service, he's always gone out of his way for me.
He had an opportunity to go work for a company doing some really leading edge motorsports stuff so we lost his focus for about a year but he was still doing cams just wasn't doing much advertising. But that company went under so he back working for himself now for well over a year now.
If you call him, be sure and ask him about lifter and spring recommendations, hopefully your spring will work since they don't have but 20mins of run time on them.
Re: what cam would you use? [Re: Brian Hafliger] #528584
11/17/09 03:03 PM
11/17/09 03:03 PM
BradH Offline
BradH  Offline
That's funny, since that's exactly what I'd have suggested if he had more work to the heads and a 3-speed trans.
Re: what cam would you use? [Re: BradH] #528585
11/17/09 08:06 PM
11/17/09 08:06 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
thanks for all the replys,called scott brown and he hooked me up for my combo,which uses specs close to what was recomended here ,thaks again,sam.
