what cam would you use?
#528570
11/16/09 09:59 PM
11/16/09 09:59 PM
Posts: 1,285 okla.
sam64
okla.
iv'e sent my specs to comp and lunati no replys so i'll ask those here,combo is 500" indy 440-1 otb 12to1 comp,indy single plane 4150 flange,4500 stall power-gide,4.56 gear,14x32 m/ts,3000lbs race wt,would like to stay around 7200 max rpm,1.5 rockers.this is a foot-brake car.thanks,sam.i have 1000cfm hp or 1050 dom for carbs. forgot looking at solid flat tappet.
Re: what cam would you use?
[Re: sam64]
#528571
11/16/09 10:26 PM
11/16/09 10:26 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
267/274 @.050 .617/.612 w/1.5 ratio on a 110lca advanced 5°. That's what I would run....
Brian Hafliger
[Re: sam64]
#528572
11/16/09 11:20 PM
11/16/09 11:20 PM
BradH
FWIW (just another opinion to throw into the mix), I'd try something like this, only ground on 110 LSA and installed on 106 ICL. EDIT: On second thought, given the 2-speed trans, it might actually work better w/ the 108 LSA that linked cam is on.
[Re: sam64]
#528573
11/16/09 11:56 PM
11/16/09 11:56 PM
the smallest i'd even consider would be a mid to high 270's@.05 also, put the dominator on it.
#528574
11/17/09 12:28 AM
11/17/09 12:28 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I missed the otb comment...if your not porting them at all then yeah, I'd run 276/280 @.050 still on a 110lca though. Are the heads untouched?
Brian Hafliger
[Re: Brian Hafliger]
#528575
11/17/09 12:57 AM
11/17/09 12:57 AM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
...so that .650 McCandless Special was a little too much in my 500 -1 OOTB stroker with a 4500?....what ya got in plan for my new bullet?
[Re: Chassisman]
#528576
11/17/09 02:58 AM
11/17/09 02:58 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
It all depends on what you let me get away with power wise...!! More power, how's that!
Brian Hafliger
#528578
11/17/09 04:02 AM
11/17/09 04:02 AM
Chassisman
Chowchilla,ca
Well I'm diggin the pump gas route.....
[Re: sam64]
#528580
11/17/09 02:24 PM
11/17/09 02:24 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Sam, here's the Scott Brown solid I'm using: .648/.640 274/280 112 lobe sep, 108 intake centerline
Here are the specs on 440Jim's Scott Brown cam that got him in the mid 9s .623/.600 272/280 112 lobe sep
Here are the specs on 440Jim's Comp cam that he's running now: MM-305S-10 .650/.650 279/287 110 lobe sep
Here's that big Ray Barton that I have if your interested (only has 25 passes on it, with lifters, already broken in but may be a little big): .639/.640 283/284 108 lob sep, 104 int centerline
I'd also recommend using the newer lifters with the EDM hole in them to provide some extra insurance against lobes going flat. I got mine from Hughes, I know Jim runs EDM lifters as well.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: sam64]
#528581
11/17/09 02:34 PM
11/17/09 02:34 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you loosen the converter to 5500 plus rpm, you can go a lot bigger than you might think. I just found an old time slip that showed my car with a 499 lowdeck, 440-1 with bowl porting only, alky injected 12.5/1 compression at 3000Lbs went 143.3 mph, 9.340 with a horrible 1.366 60 ft. I had an ultrdyne roller in it, 283 @ .050 int, 290 @ .050 exh, 108 lsa . Corrected altitude for that run was 1650 ft. Shifting at 6800 rpm.
[Re: sam64]
#528583
11/17/09 02:51 PM
11/17/09 02:51 PM
WadeMetzinger
Tulsa, Ok
Nope, Racer Brown is "old School" been around for many years and I don't mean any disrespect by the "old school" comment. His cams are very proven and many guys love his cam profiles. I've never ran one but I've heard a lot of people speak highly of them. Scott Brown is Straight Line Performance: http://www.buyracingparts.com/He's a younger guy, and very very well respected cam spec and builder for a lot of people here on Moparts. A year or so ago that's about all any one was running. He's a mopar guys and has a lot of knowledge on Mopars. Here is his number (616-499-6223) , you can tell him about your car and motor and he will send you his recommendation for a cam. I've ran about 4 of his cams, great guy, great personal service, he's always gone out of his way for me. He had an opportunity to go work for a company doing some really leading edge motorsports stuff so we lost his focus for about a year but he was still doing cams just wasn't doing much advertising. But that company went under so he back working for himself now for well over a year now. If you call him, be sure and ask him about lifter and spring recommendations, hopefully your spring will work since they don't have but 20mins of run time on them.
#528584
11/17/09 03:03 PM
11/17/09 03:03 PM
BradH
That's funny, since that's exactly what I'd have suggested if he had more work to the heads and a 3-speed trans.
