1964-65 A-990 Race Hemi Pulleys *DELETED* #527848
11/16/09 12:29 PM
11/16/09 12:29 PM
Arkansas
beatupcuda Offline OP
Arkansas
Post deleted by 68Cuda hemi4spd
Re: 1964-65 A-990 Race Hemi Pulleys [Re: beatupcuda] #527849
11/16/09 02:18 PM
11/16/09 02:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i have seen them recently , can't remember where , did you check epay ?
Re: 1964-65 A-990 Race Hemi Pulleys [Re: JohnRR] #527850
11/16/09 04:43 PM
11/16/09 04:43 PM
Colorado
hemi69cuda Offline
hemi69cuda  Offline
Colorado
what is the difference between the max wedge pullys and hemi race pullys and the ones your looking for.
Re: 1964-65 A-990 Race Hemi Pulleys [Re: hemi69cuda] #527851
11/16/09 04:54 PM
11/16/09 04:54 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I have a attic full of different Hemi and wedge pulleys.What constitutes a specific 64/65 race Hemi pulley?I even have some that came off NASCAR Hemis. No repops
Re: 1964-65 A-990 Race Hemi Pulleys [Re: B G Racing] #527852
11/16/09 06:25 PM
11/16/09 06:25 PM
EMAIL SENT PICS INCLUDED.
Re: 1964-65 A-990 Race Hemi Pulleys [Re: hemi69cuda] #527853
11/16/09 06:28 PM
11/16/09 06:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
max wedge lower pulley would be a different depth assuming the 64/65 Race hemi had the wide balancer like the later street hemis
Re: 1964-65 A-990 Race Hemi Pulleys #527854
11/16/09 06:30 PM
11/16/09 06:30 PM
Re: 1964-65 A-990 Race Hemi Pulleys #527855
11/16/09 06:38 PM
11/16/09 06:38 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I thought 64/65 race Hemis had the thin damper All the race dampers I aquired from Chrysler were of the thin variety.66 and up street Hemis used the thick one.
Re: 1964-65 A-990 Race Hemi Pulleys [Re: beatupcuda] #527856
11/16/09 06:47 PM
11/16/09 06:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '64-'65 Hemi damper and pulleys all have Hemi only part numbers but, never having seen them, I can't say what the difference(s) are.
Jim Kramer would know.
Re: 1964-65 A-990 Race Hemi Pulleys [Re: John_Kunkel] #527857
11/16/09 07:39 PM
11/16/09 07:39 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I believe all 64-65 Hemis use the thin crank balancer. This would make the pullies the longer pullies.I have never searched to see if the pullies were the same as any other Mopar engine. Also the 64 flywheels are a lot different from the 66-69 flywheels and the 70-71 flywheels.
1971 HEMI E BODY REGISTRY
Re: 1964-65 A-990 Race Hemi Pulleys [Re: hemicar1971] #527858
11/16/09 07:47 PM
11/16/09 07:47 PM
HES talking about alternator deep groove pulleys
Re: 1964-65 A-990 Race Hemi Pulleys [Re: John_Kunkel] #527859
11/16/09 07:47 PM
11/16/09 07:47 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Chrysler themselves couldn't keep it straight as far as the part numbers.They listed the damper under quite a few preceeding numbers.The 64/65 race only thin damper is list as P-2532795,P-3830183 and P-5249698 the thick NASCAR and street Hemi is listed as P-2532202,P-3870854 and P-5249699.The 440/383 wedge was also listed as P-3830183(the same as the race Hemi)Chrysler also claimed the timing marks differ from the thick and thin damper.GO FIGURE,to add to all the confusion there is a mismatch of superceeding numbers from way back.Also a hodpodge of pulleys with different size,ratio,depth and diameter.Who wants to be the expert and claim the exact part#s and discription.NOT ME
Re: 1964-65 A-990 Race Hemi Pulleys [Re: beatupcuda] #527860
11/16/09 10:35 PM
11/16/09 10:35 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
64 and 65 race hemi pulleys have the large or deep double grove in the alt. The the crank and water pump have the same size groove. The only difference between the max wedge crank pulley and the race hemi is the race hemi is smaller in diameter. Only the alt pulley has a part number it. Repops are made of all three.The alt repop does not have the part number. The race hemi balancer is the same thickness as a std wedge motor but it has a finer finish on the outer ring instead of the turned look of a stock one. I have seen an NOS one unpanited and it is easy to see the difference. It had a ink stamped part number on it. I have a picture of mine but it is hard to see the difference in a picture. It looks like it was ground with a stone instead of a steel tool. Jim Krammer does sell the repops.
Re: 1964-65 A-990 Race Hemi Pulleys [Re: B G Racing] #527861
11/17/09 10:52 AM
11/17/09 10:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't know that , if that case then ones I saw listed for max wedge and race hemi would be the same ???
Re: 1964-65 A-990 Race Hemi Pulleys *DELETED* [Re: B G Racing] #527862
11/19/09 09:12 AM
11/19/09 09:12 AM
Arkansas
Arkansas
68 Hemi 4 speed Cuda,,,,building ?
Re: 1964-65 A-990 Race Hemi Pulleys [Re: beatupcuda] #527863
11/19/09 09:19 AM
11/19/09 09:19 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
I was told my rebuild of a 68 SS Cuda originally had 65 A-990 pulleys,????
Not on the crank pulley. The 68 had a standard "thick" hemi balancer and needed a special deep single groove pulley.
DC
Re: 1964-65 A-990 Race Hemi Pulleys [Re: beatupcuda] #527864
11/19/09 02:36 PM
11/19/09 02:36 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
So BOB, why do you not want to answer me on sizes & if you want to sell any ?
Jeff,I'am not trying to sell anything,I'am not going to tell anyone which pulleys are the exact size.We are not in the restoration(hype) business.Anyone who wants to come to the shop and dig through the tons of junk is more than welcome or if they want to send the
demensions of the pulleys they are looking for I may have one of the guys look for them.As stated having been through that era and seen the hodpodge and mismatch of what Chrysler put out with the max-wedge and Hemi cars nothing seem to surprise me and I'am not going to be the one to say "this is the fact or part"and get in a pissing match with all the Gurus.Best to contact Jim Kramer.I sold(gave) him his first race car.
Re: 1964-65 A-990 Race Hemi Pulleys *DELETED* [Re: B G Racing] #527865
11/19/09 04:44 PM
11/19/09 04:44 PM
Arkansas
Arkansas
Re: 1964-65 A-990 Race Hemi Pulleys [Re: beatupcuda] #527866
11/19/09 04:51 PM
11/19/09 04:51 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
OK Bob, my mistake, sorry, just needing someone to let me know "to the best of their knowledge"
What size pulleys were used on the 68 SS cuda, as I have read the 65 A-990 hemi cars, pulleys were used as that's what was available, unfortunately I have no idea what size the A-990 were either, so thinking you have probably seen a LOT of original stuff, a BEST GUESS would help !!!! And if you happened to have some for sale, I need them, so as of today, I think I need a alt & water pump pulley from a 65 A-990 hemi,.....thanks, and PS, I understand about the guru contest,,,,,,,
Jim Kramer 724-285-5566
Re: 1964-65 A-990 Race Hemi Pulleys [Re: B G Racing] #527867
11/19/09 04:58 PM
11/19/09 04:58 PM
i gave jeff all the pictures and sizes he needs but he doesnt seem to know what he needs. i have the correct pulleys for his application./
