Can't get this 91 Acclaim running
#524646
11/12/09 11:19 PM
11/12/09 11:19 PM
Posts: 3,753 Gulf Coast of Florida
Russ
super gas
super gas
One owner only 61.000 miles,been sitting for 3 years,I had It towed here today,very nice car. Pulled the plugs,turned It over without the cap,till I got oil pressure,buttoned up everything,tried to fire It up,nothing!!!! turns over real nice,so I poured a little gas Into the throttle body,It fires right up,then dies,did It again,same thing,and over 10 times,same thing,I dump some gas into the throttle body,It runs for about 10 seconds and dies,Where Is the fuel pump on these cars? 2.5 auto. Any help here???? PM me for help Thanks
2001 Durango 5.9 Magnum
99 Durango 5.9 Magnum
Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9
WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me.
GO BUCKS!!!!
Go GATORS!!!!
Re: Can't get this 91 Acclaim running
[Re: Russ]
#524647
11/12/09 11:25 PM
11/12/09 11:25 PM
Posts: 4,872 connecticut
pnypwr
connecticut
prob in the tank, check the fuses first, or at least to make sure you got power at the pump
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#524648
11/12/09 11:29 PM
11/12/09 11:29 PM
Russ
super gas
super gas
I got frustrated with It tonight,but i'll check that out tomorrow,Is the fuel pump fuse with the rest of them by the dashboard/
GO BUCKS!!!!
Go GATORS!!!!
[Re: Chilort]
#524650
11/12/09 11:40 PM
11/12/09 11:40 PM
Russ
super gas
super gas
Thanks ![](/ubbthreads/images/graemlins/thumbs.gif) I only get my stuff from Napa anyway ![](/ubbthreads/images/graemlins/thumbs.gif) Autozone ![](/ubbthreads/images/graemlins/hammer.gif) Advance ![](/ubbthreads/images/graemlins/hammer.gif) Pep Boys ![](/ubbthreads/images/graemlins/hammer.gif)
GO BUCKS!!!!
Go GATORS!!!!
[Re: Russ]
#524651
11/13/09 08:52 AM
11/13/09 08:52 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Before dropping the tank, you might look to make sure that the pump is getting voltage. Hate to see you go to all that trouble and the fuse was out. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 62maxwgn]
#524656
11/13/09 01:21 PM
11/13/09 01:21 PM
Russ
super gas
super gas
Is the relay under the hood,or in the fusebox? I already banged on the bottom of the tank,didn't do any good,It's got 3/4 of a tank of gas,and It still smells decent
GO BUCKS!!!!
Go GATORS!!!!
[Re: Russ]
#524658
11/13/09 02:41 PM
11/13/09 02:41 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I had a similar problem on the wifes 91 full size van. I replaced the pump and still got nothing. Turned out to be the pick up in the Dist. Apparently the pick up tells the computer that the engine is rotating and to turn the pump on.
I don't know if the accliam is the same or not.
Good luck.
[Re: burdar]
#524660
11/13/09 04:25 PM
11/13/09 04:25 PM
Posts: 1,534 Florida
CHRGR69
Check the phasing ring that passes between the pickup in the dizzy. I had the same symptoms. Turns out the ring was rusted bad.
Grandma always said I had "hands of gold"!
[Re: Scottmon]
#524662
11/13/09 10:11 PM
11/13/09 10:11 PM
Russ
super gas
super gas
I'll check the the dist.and the codes tomorrow. It's driving me nuts ![](/ubbthreads/images/graemlins/wrench.gif)
GO BUCKS!!!!
Go GATORS!!!!
