Can't get this 91 Acclaim running #524646
11/12/09 11:19 PM
11/12/09 11:19 PM
Gulf Coast of Florida
Russ Offline OP
super gas
Russ  Offline OP
super gas
One owner only 61.000 miles,been sitting for 3 years,I had It towed here today,very nice car.
Pulled the plugs,turned It over without the cap,till I got oil pressure,buttoned up everything,tried to fire It up,nothing!!!!
turns over real nice,so I poured a little gas Into the throttle body,It fires right up,then dies,did It again,same thing,and over 10 times,same thing,I dump some gas into the throttle body,It runs for about 10 seconds and dies,Where Is the fuel pump on these cars?
2.5 auto.
Any help here????
PM me for help
2001 Durango 5.9 Magnum 99 Durango 5.9 Magnum Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9 WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me. GO BUCKS!!!! Go GATORS!!!!
Re: Can't get this 91 Acclaim running [Re: Russ] #524647
11/12/09 11:25 PM
11/12/09 11:25 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
prob in the tank, check the fuses first, or at least to make sure you got power at the pump
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Can't get this 91 Acclaim running [Re: pnypwr] #524648
11/12/09 11:29 PM
11/12/09 11:29 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
I got frustrated with It tonight,but i'll check that out tomorrow,Is the fuel pump fuse with the rest of them by the dashboard/
Re: Can't get this 91 Acclaim running [Re: Russ] #524649
11/12/09 11:33 PM
11/12/09 11:33 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Fuel pump is in the tank. On my Daytona (very similar) you pretty much have to drop the back of the tank to get to the fuel pump. If it needs a new fuel pump STAY AWAY from AirTek (i.e. AutoZone, O'Reilly, etc). Pep Boys sells Carter. NAPA likely has a quality pump.
Re: Can't get this 91 Acclaim running [Re: Chilort] #524650
11/12/09 11:40 PM
11/12/09 11:40 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
I only get my stuff from Napa anyway
Autozone
Advance
Pep Boys
Re: Can't get this 91 Acclaim running [Re: Russ] #524651
11/13/09 08:52 AM
11/13/09 08:52 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Before dropping the tank, you might look to make sure that the pump is getting voltage. Hate to see you go to all that trouble and the fuse was out.
Craig
Re: Can't get this 91 Acclaim running [Re: denfireguy] #524652
11/13/09 08:55 AM
11/13/09 08:55 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
or the fuel filter is pluged!!!
Re: Can't get this 91 Acclaim running [Re: 71_deputy] #524653
11/13/09 10:07 AM
11/13/09 10:07 AM
Russ Offline OP
super gas
Russ  Offline OP
super gas
Thanks for the replies,i'll look for the fuse and check the filter
Re: Can't get this 91 Acclaim running [Re: Russ] #524654
11/13/09 11:08 AM
11/13/09 11:08 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Have a helper crank the engine over while you slap the bottom of tank a bit, it might wake the pump up.
Re: Can't get this 91 Acclaim running [Re: buildanother] #524655
11/13/09 12:34 PM
11/13/09 12:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Or replace the fuel pump relay,they corrode from sitting.The relays are all the same,pull one that operates something and see what happens before you go buying parts you don't need.
Re: Can't get this 91 Acclaim running [Re: 62maxwgn] #524656
11/13/09 01:21 PM
11/13/09 01:21 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
Is the relay under the hood,or in the fusebox?
I already banged on the bottom of the tank,didn't do any good,It's got 3/4 of a tank of gas,and It still smells decent
Re: Can't get this 91 Acclaim running [Re: Russ] #524657
11/13/09 02:40 PM
11/13/09 02:40 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Just turn the key to the run possition and listen for the pump to run. If it runs, your problem is elsewhere. FYI...the pump will only run for a couple seconds before turning off again.
Re: Can't get this 91 Acclaim running [Re: Russ] #524658
11/13/09 02:41 PM
11/13/09 02:41 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I had a similar problem on the wifes 91 full size van. I replaced the pump and still got nothing. Turned out to be the pick up in the Dist. Apparently the pick up tells the computer that the engine is rotating and to turn the pump on.
I don't know if the accliam is the same or not.
Good luck.
Re: Can't get this 91 Acclaim running [Re: WILD BILL] #524659
11/13/09 02:46 PM
11/13/09 02:46 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If the pick up was bad I don't think it would start at all.
Re: Can't get this 91 Acclaim running [Re: burdar] #524660
11/13/09 04:25 PM
11/13/09 04:25 PM
CHRGR69 Offline
CHRGR69  Offline
Check the phasing ring that passes between the pickup in the dizzy. I had the same symptoms. Turns out the ring was rusted bad.
Grandma always said I had "hands of gold"!
Re: Can't get this 91 Acclaim running [Re: CHRGR69] #524661
11/13/09 04:28 PM
11/13/09 04:28 PM
Louisville, KY.
Scottmon Offline
Scottmon  Offline
Louisville, KY.
First step....check for codes.
Turn the key off and on three times...leave on the third time. Check engine light should probably flash once, then twice for code 12 and five followed by five (55) for end of test. Get any other codes post them here.
Re: Can't get this 91 Acclaim running [Re: Scottmon] #524662
11/13/09 10:11 PM
11/13/09 10:11 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
I'll check the the dist.and the codes tomorrow.
It's driving me nuts
Re: Can't get this 91 Acclaim running [Re: Russ] #524663
11/14/09 05:10 AM
11/14/09 05:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If it starts pouring gas in it the dist is fine so I would not waste your time on it. Just have someone crank the eng while you check for voltage to the pump. If you have voltage then have someone turn the key to the run posistion while you listen at the tank to hear the pump run. As was stated it will only run a few seconds that way. If you dont hear it run the its a bad fuel pump or a bad ground for the pump. If you hear it run I would check the fuel filter first but it could still be a damaged pump blades. If you did not have voltage at the pump then you need to check the wiring. Thats the easiest thing for you to do. Ron
