Re: 8 point rollbar in a 64 Dart
[Re: The Shocker]
#520738
11/09/09 11:00 PM
11/09/09 11:00 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Before you do anything with the roll abr and door bars position the seat your going to use and check your location and comfort positions in the seat and then make the measurements as faras where the main hoop will need to be and how high it needs to be before fabricating anything else. You may need to make stands on the floor for the main hoop to be welded to to get the hieght correct if your very tall or have the seat raised up for better vision over the dash Measure twice, three times before cutting and welding once I have a 1965 dart 270 two door hardtop that will get some attention next year, I hope
