8 point rollbar in a 64 Dart #520734
11/09/09 05:56 PM
11/09/09 05:56 PM
Sherman Texas
The Shocker Offline OP
Sherman Texas
I just got my 8 point rollbar from S an W racecars ,and it looks great ,plus the main hoop fits very well.I was hoping maybe someone had a few pics of an 8 point setup in 63-66 Dart ,so i can get a better idea of how it goes in as far as the floor locations.I have the instructions ,but pics would be even better if you have the time to take me a few of your finished roll bar ,thanks ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: 8 point rollbar in a 64 Dart [Re: The Shocker] #520735
11/09/09 07:33 PM
11/09/09 07:33 PM
okla.
sam64 Offline
sam64  Offline
okla.
do you have a nhra or ihra rule book?you kinda need to look at their rules,as in how far above your head,how far behind your head the main hoop goes.do your self a favor if you don't have a tubing notcher find someone who does,also a sliding t bevel from lumber yard to get the angles.take your time, measure,then measure again.i bought a 67 cuda that came from around texas raceway,super pro car.good luck.
Re: 8 point rollbar in a 64 Dart [Re: sam64] #520736
11/09/09 08:17 PM
11/09/09 08:17 PM
Sherman Texas
Sherman Texas
Thanks Sam ,this kit already has the bars notched though.It even came with the specs on the measurments for the NHRA (distance from helment ,from roof, etc) with the instructions .I just wanted to see some pics of one welded together for a reference.Got yourself another A body huh? You gunna make it a dragcar ?I used to have a 68 Cuda convertable in high school .Good luck with it ,which ever way you go .Thanks again for this Dart ,i love it ...
Re: 8 point rollbar in a 64 Dart [Re: The Shocker] #520737
11/09/09 08:34 PM
11/09/09 08:34 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Go to Chris Alstons web site , click on install articles, then roll bar install.
Re: 8 point rollbar in a 64 Dart [Re: The Shocker] #520738
11/09/09 11:00 PM
11/09/09 11:00 PM
Before you do anything with the roll abr and door bars position the seat your going to use and check your location and comfort positions in the seat and then make the measurements as faras where the main hoop will need to be and how high it needs to be before fabricating anything else. You may need to make stands on the floor for the main hoop to be welded to to get the hieght correct if your very tall or have the seat raised up for better vision over the dash Measure twice, three times before cutting and welding once I have a 1965 dart 270 two door hardtop that will get some attention next year, I hope
Re: 8 point rollbar in a 64 Dart [Re: Cab_Burge] #520739
11/10/09 10:35 AM
11/10/09 10:35 AM
St. Louis, MO
I
Izzys Cages Offline
Izzys Cages  Offline
I
St. Louis, MO
Absolutely install the seat first to get your head location, harness height, seatback location, elbow/armpit area and clearance for the seat. Everything else depends on the seat position.
You will have to modify the notches to fit correctly.
Re: 8 point rollbar in a 64 Dart [Re: Izzys Cages] #520740
11/10/09 06:49 PM
11/10/09 06:49 PM
Sherman Texas
Sherman Texas
The seat has been mounted for last several trips to the track ,and its perfectly comfy for me where its at.I was told by the guy at S and W racecars that it may have to be slightly trimed to fit perfect .Anything else i should know before i start?
