540 cubes. Some questions for the engine guru's.
#519962
11/08/09 08:40 PM
11/08/09 08:40 PM
Posts: 90 Canada
moparmat
Canada
Who makes the lightest pistons available in standard over bore sizes (.030-.060) for a 4.5 stroke raised deck block? 1.320 CH. Also looking to use 7.1 aluminum rods with small block C***y journals in this mill. Anyone have any clearance issues with alu. rods in stock/standard BB blocks with 4.5 stroke? Thinking R&R, BME, or GRP. Engine will be driven on the street ocassionally. Callies crank. moparmat
Re: 540 cubes. Some questions for the engine guru's.
[Re: moparniac]
#519968
11/09/09 08:26 PM
11/09/09 08:26 PM
Posts: 9,999 Frostbitefalls MN (Rocky&Bullw...
gregsdart
you can run a 4.5 crank in a 440 block?
yes
And with a 2.375 rod bearing no less! so figure what you can run with a 2.200,,,,, a 4.60?
[Re: moparmat]
#519969
11/09/09 08:51 PM
11/09/09 08:51 PM
Posts: 78 tampa florida
elephant express
tampa florida
I have a 4.5 billet crank with 2.200 rod journals if you need one. $700.00 all machine work is already done. And use steel rods. I'm running a set of manleys 7.100 and diamond 8:1 pistons and Ray Barton says thy can handle up to 2000 hp. I'm running a blown KB on the street. Not at 2000 hp but at 1200 hp! I will try 2000hp at track time!! Thanks Joe
