Tire Shop Guys - TPS question/valve stems #518125
11/07/09 12:20 PM
11/07/09 12:20 PM
Washington Twp., Southern NJ
Fastfrankie Offline OP
Quick question - is it really necessary to buy that valve core screwdriver/driver to properly torque the valve core in the stem?
I don't mind spending $25 in the screwdriver tool from Lisle. Just curious if it is really necessary, as long as you don't overtorque/strip the stem.
Any tips or advice when changing out tires with rims that have TPS valve stems? I don't see alot of these come into my shop.
Re: Tire Shop Guys - TPS question/valve stems [Re: Fastfrankie] #518126
11/07/09 01:37 PM
11/07/09 01:37 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I did some at work before.Just used the regular VS remover.Just snug them.The Advanced store had a new S10 truck that the rubber seal to the rim was leaking.I fiked that with a rubber from a thread in valve stem.The GM dealer couldnt get one and they only sold the whole unit.Its still working and that was almost a year ago.Rocky
Chrysler Firepower
Re: Tire Shop Guys - TPS question/valve stems [Re: Fastfrankie] #518127
11/07/09 03:45 PM
11/07/09 03:45 PM
you might see if you can locate one of those metal chrome valve stem caps that has the slotted nub on top for that very purpose. Even if you bought a new set of 4 cheapies in a blister pack it'd sure be cheaper than $25.
Re: Tire Shop Guys - TPS question/valve stems [Re: RapidRobert] #518128
11/07/09 04:30 PM
11/07/09 04:30 PM
Do you realize what I am talking about? Have you recently worked on any rims with TPS? I get the feeling you really haven't.
If you have, then you'd know exactly what I am talking about as far as torquing them down to prevent stripping it out and damaging the TPS unit or getting messages on your monitor that your tires are low on air all of the time!
FYI- they make a screwdriver tool that properly torques the valve core into the TPS stem -something like 3-5 inch pounds. It has to be torqued to spec. It ain't like the old days when you just tightened the hell out of the core with the core installer screwdriver my friend!
Re: Tire Shop Guys - TPS question/valve stems [Re: RapidRobert] #518129
11/07/09 04:38 PM
11/07/09 04:38 PM
Az
Crizila Offline
Crizila  Offline
Az
I do this on some of the older stuff I own. One package will cover 4 cars. Here is a tip that can save you some $$$$$. Some of the later model cars ( those with air pressure sensors attached to valve stems, use aluminum valve stems. Do not screw steel caps on these stems ( they come with wimpy looking plastic caps for a reason ). If you switch to steel caps, you will end up with a dissimilar metal corrosion problem right where the metal cap stops on the threaded portion of the valve stem. When you go to check tire pressure, the stem will snap off right at the cap threads due to the corrosion in that area. Only repair is a new sensor / stem. That will be $130 please. Being the dumb arss that I am, took me twice to figure it out:(
Fastest 300
Re: Tire Shop Guys - TPS question/valve stems [Re: Fastfrankie] #518130
11/07/09 04:55 PM
11/07/09 04:55 PM
Do you realize what I am talking about? Have you recently worked on any rims with TPS? I get the feeling you really haven't. It ain't like the old days when you just tightened the hell out of the core with the core installer screwdriver my friend!
I kinda thought I was missing something. The TPS should have been the tipoff. My bad
Re: Tire Shop Guys - TPS question/valve stems [Re: RapidRobert] #518131
11/07/09 06:26 PM
11/07/09 06:26 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
You may not have had them much,but they are getting more and more common.
FWIW,buy the kit that has the torque wrench,valve stem core tool and the service kits.
Bridgeport/Schrader has a complete kit our shop uses.
It is recommended to replace the O-ring,nut,and crush sleeve on most TPMS sensors when servicing tires.
The GM valve stems are available from them and as well from the dealer.
I attended the training seminars and the proper way to dismount a tire wiht a TPMS sensor is remove the valve core,then nut and push the sensor inside the tire and break the tire down.
Of course the guys in the shop skip that and break the bead 180 degrees away from the sensor.
The problem our shop exprienced is Northern climates with salt on the roads can sieze up the valve cores.We have snapped many a sensor that is corroded from winter driving.
It is important to have correct valve stem caps on the sensors.
Fancy chrome caps,or regular plastic ones do not keep moisture out.
Make sure you "test" the valve core before going further.If it is not going to come out,tell the customer heads up that a new sensor may be required.Make sure you get price and availability before proceeding so you wont have a sitting duck on your hands.
Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Tire Shop Guys - TPS question/valve stems [Re: 68Cbarge] #518132
11/07/09 06:41 PM
11/07/09 06:41 PM
Can you recommend any kit with those tools etc?
I was looking at a Lisle driver for $25.00 shipped. No core tool though.
Re: Tire Shop Guys - TPS question/valve stems [Re: Fastfrankie] #518133
11/07/09 07:31 PM
11/07/09 07:31 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Check out this page:
http://www.schrader-bridgeport.com/index...&Itemid=111
Contact your jobber and see if they deal with Schrader.
We use their kits and tools in our shop.
As noted on the site,never use the regular brass valve cores with the TPMS sensors--always use the nickle plated cores.
Re: Tire Shop Guys - TPS question/valve stems [Re: 68Cbarge] #518134
11/08/09 09:02 AM
11/08/09 09:02 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Like I said I did a bunch at work.I was just careful not to get zealous reinstalling the stem.Its like rotating tires on them.You have to reset them on the car to shut the light off.We rotated then turn on ign let some air out reair and wait for the horn to beep to recoginise the sensor.Just more work and then people wonder why working on the new stuff costs more.We had one girl with a Pontiac that kept bending rims.She wnet thru 5 new ones and we straightened 4 more.She kept hitting pretty much the same pot hole.Never guess what color hair she had.Rocky
Chrysler Firepower
Re: Tire Shop Guys - TPS question/valve stems [Re: therocks] #518135
11/08/09 09:32 AM
11/08/09 09:32 AM
So anytime you rotate the tires on a car with TPS, you have to reset the light? Didn't know that.
So once you rotate the tires, turn on the ignition switch to on position, then you let air out of each one until its about 20 psi. Then re-air them to correct pressure and the horn will beep when the sensors are recognized?
Re: Tire Shop Guys - TPS question/valve stems [Re: Fastfrankie] #518136
11/08/09 09:40 AM
11/08/09 09:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Thats what you have to do on GMs for sure.Takes about 20 minutes total.Have to start charging more than 12 bucks to rotate tires.Rocky
Chrysler Firepower
Re: Tire Shop Guys - TPS question/valve stems [Re: Fastfrankie] #518137
11/08/09 05:59 PM
11/08/09 05:59 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Frankie you need to add a "W" to your explanation,TPS means T-hrottle P-osition S-ensor and TPWS means T-ire P-ressure W-arning S-ensor. Now with terminology out of the way you can get a kit from your local Toyota dealer that has a nut,washer,and seal to repair the "TPWS".
Gus
64 Plymouth Savoy
Dana 60
Re: Tire Shop Guys - TPS question/valve stems [Re: fourgearsavoy] #518138
11/08/09 07:34 PM
11/08/09 07:34 PM
Gus
You can also use the acronym:
TPMS - Tire Pressure Monitoring System if you like
Re: Tire Shop Guys - TPS question/valve stems [Re: Fastfrankie] #518139
11/08/09 08:48 PM
11/08/09 08:48 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
How do the sensors communicate with the car?
Re: Tire Shop Guys - TPS question/valve stems [Re: Snoopy] #518140
11/08/09 09:09 PM
11/08/09 09:09 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Sorry,I could not resist.
Seriously,Each wheel has a battery powered radio transmitter that reads the tire pressure and sends a signal to the car's computer and displays the pressure on most models and other just have a light that comes on when the pressure is low.
Each manufacture has a setting at a certain pressure to turn the light on.
The valve stem actually doubles as the antennae for the transmitter.
Re: Tire Shop Guys - TPS question/valve stems [Re: 68Cbarge] #518141
11/09/09 12:34 AM
11/09/09 12:34 AM
Snoopy Offline
Snoopy  Offline
Thanks for the answer. I found this on the link listed above.
TPMS sensors measure tire pressure and transmit this information via radio frequencies to the vehicle’s electronic control unit (ECU). Some Schrader TPMS sensors also measure tire temperature.
Re: Tire Shop Guys - TPS question/valve stems [Re: Fastfrankie] #518142
11/09/09 07:06 AM
11/09/09 07:06 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
it actually depends on the car, if it has the tire pressure monitor (tells you pressure at each corner) it needs to be recalibrated. if you have just idiot light then it does not need to be recalibrated on a rotation
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
