Re: Tire Shop Guys - TPS question/valve stems
[Re: Fastfrankie]
#518126
11/07/09 01:37 PM
11/07/09 01:37 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I did some at work before.Just used the regular VS remover.Just snug them.The Advanced store had a new S10 truck that the rubber seal to the rim was leaking.I fiked that with a rubber from a thread in valve stem.The GM dealer couldnt get one and they only sold the whole unit.Its still working and that was almost a year ago.Rocky
Chrysler Firepower
[Re: Fastfrankie]
#518127
11/07/09 03:45 PM
11/07/09 03:45 PM
RapidRobert
you might see if you can locate one of those metal chrome valve stem caps that has the slotted nub on top for that very purpose. Even if you bought a new set of 4 cheapies in a blister pack it'd sure be cheaper than $25.
[Re: RapidRobert]
#518128
11/07/09 04:30 PM
11/07/09 04:30 PM
Posts: 1,755 Washington Twp., Southern NJ
Fastfrankie
Do you realize what I am talking about? Have you recently worked on any rims with TPS? I get the feeling you really haven't.
If you have, then you'd know exactly what I am talking about as far as torquing them down to prevent stripping it out and damaging the TPS unit or getting messages on your monitor that your tires are low on air all of the time!
FYI- they make a screwdriver tool that properly torques the valve core into the TPS stem -something like 3-5 inch pounds. It has to be torqued to spec. It ain't like the old days when you just tightened the hell out of the core with the core installer screwdriver my friend!
[Re: RapidRobert]
#518131
11/07/09 06:26 PM
11/07/09 06:26 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
You may not have had them much,but they are getting more and more common. FWIW,buy the kit that has the torque wrench,valve stem core tool and the service kits. Bridgeport/Schrader has a complete kit our shop uses. It is recommended to replace the O-ring,nut,and crush sleeve on most TPMS sensors when servicing tires. The GM valve stems are available from them and as well from the dealer.
I attended the training seminars and the proper way to dismount a tire wiht a TPMS sensor is remove the valve core,then nut and push the sensor inside the tire and break the tire down. Of course the guys in the shop skip that and break the bead 180 degrees away from the sensor.
The problem our shop exprienced is Northern climates with salt on the roads can sieze up the valve cores.We have snapped many a sensor that is corroded from winter driving. It is important to have correct valve stem caps on the sensors. Fancy chrome caps,or regular plastic ones do not keep moisture out. Make sure you "test" the valve core before going further.If it is not going to come out,tell the customer heads up that a new sensor may be required.Make sure you get price and availability before proceeding so you wont have a sitting duck on your hands. Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: Fastfrankie]
#518133
11/07/09 07:31 PM
11/07/09 07:31 PM
68Cbarge
Canuckville
Check out this page: http://www.schrader-bridgeport.com/index...&Itemid=111Contact your jobber and see if they deal with Schrader. We use their kits and tools in our shop. As noted on the site,never use the regular brass valve cores with the TPMS sensors--always use the nickle plated cores.
[Re: 68Cbarge]
#518134
11/08/09 09:02 AM
11/08/09 09:02 AM
therocks
Niles , Ohio
Like I said I did a bunch at work.I was just careful not to get zealous reinstalling the stem.Its like rotating tires on them.You have to reset them on the car to shut the light off.We rotated then turn on ign let some air out reair and wait for the horn to beep to recoginise the sensor.Just more work and then people wonder why working on the new stuff costs more.We had one girl with a Pontiac that kept bending rims.She wnet thru 5 new ones and we straightened 4 more.She kept hitting pretty much the same pot hole.Never guess what color hair she had.Rocky
Chrysler Firepower
[Re: therocks]
#518135
11/08/09 09:32 AM
11/08/09 09:32 AM
Fastfrankie
So anytime you rotate the tires on a car with TPS, you have to reset the light? Didn't know that. So once you rotate the tires, turn on the ignition switch to on position, then you let air out of each one until its about 20 psi. Then re-air them to correct pressure and the horn will beep when the sensors are recognized?
[Re: Fastfrankie]
#518136
11/08/09 09:40 AM
11/08/09 09:40 AM
therocks
Niles , Ohio
Thats what you have to do on GMs for sure.Takes about 20 minutes total.Have to start charging more than 12 bucks to rotate tires.Rocky
Chrysler Firepower
[Re: Fastfrankie]
#518137
11/08/09 05:59 PM
11/08/09 05:59 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Frankie you need to add a "W" to your explanation,TPS means T-hrottle P-osition S-ensor and TPWS means T-ire P-ressure W-arning S-ensor. Now with terminology out of the way you can get a kit from your local Toyota dealer that has a nut,washer,and seal to repair the "TPWS". Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#518138
11/08/09 07:34 PM
11/08/09 07:34 PM
Fastfrankie
You can also use the acronym:
TPMS - Tire Pressure Monitoring System if you like
