Page 1 of 5 1 2 3 4 5
Ring & Pinion pattern. I'm stumped. Measured it. #513944
11/02/09 02:16 AM
11/02/09 02:16 AM
Erda, UT
67Charger Offline OP
Erda, UT
17 attempts and counting...
Currently at:
.0195" shim behind driver side carrier bearing
.098" shim behind passenger side carrier bearing
.060" shim behind the big pinion bearing cup
.076" shim between the pinion and small bearing
Backlash is at .009"
Pinion free spin torque is about 3 inch pounds w/o seal. I'll be removing a few .001's from the preload shim pack to bring that up. These are new Strange gears and Timken bearings.
It looks to me like it might need some more pinion shim to bring the pinion closer to the axles. What says the hive mind? How much of what?
Drive side
Coast side
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513945
11/02/09 08:18 AM
11/02/09 08:18 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Are you using a case spreader?
Try moving the carrier .003 closer to the pinion.
Where its at right now ain`t that bad.
A perfect pattern is`nt easy to get
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Ring & Pinion pattern help needed PLEASE! [Re: 6bblFLASH] #513946
11/02/09 09:42 AM
11/02/09 09:42 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
the pinion is to close to the carrier needs to be moved out. remove pinion shim.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ring & Pinion pattern help needed PLEASE! [Re: bigtimeauto] #513947
11/02/09 09:44 AM
11/02/09 09:44 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
here is one i just did. Pinion shim was .043 backlash .005.
Re: Ring & Pinion pattern help needed PLEASE! [Re: bigtimeauto] #513948
11/02/09 09:49 AM
11/02/09 09:49 AM
ky
68roadrunner Offline
ky
move the pinion away from carrier, and you will see the drive and coast marks start to move across from each other.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 6bblFLASH] #513949
11/02/09 10:43 AM
11/02/09 10:43 AM
Erda, UT
Erda, UT
The previous setup attempt was with the carrier shimmed .006 closer to the pinion, which gave me .004 backlash and about the same pattern. I'm going to pull some pinion shim and try gain... I kept moving the pinion deeper when I was getting marks on the drive toe and coast heel. My backlash was off too, so I never saw a perfect pattern, but the marks did swap sides to drive - center, coast - toe. I guess I passed it.
I don't have a case spreader, but I have about .010" more shim in there than I can force the carrier in by hand with. I use a rubber mallet to drive it in, and it has some decent drag to it when free-spinning.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513950
11/02/09 02:52 PM
11/02/09 02:52 PM
Erda, UT
Erda, UT
-.005" pinion shim helped some, but not enough. I would venture to say about .010" more out and I'd be closer.
I'll try it and post it up after work.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513951
11/02/09 05:32 PM
11/02/09 05:32 PM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
Are you loading the gear set when checking the pattern?
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513952
11/02/09 05:51 PM
11/02/09 05:51 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Currently at:
Drive side
Coast side
All that shim on one side is telling you dont have enough shim under the inner pinion bearing..
You need to move the pinion out toward the ring gear..
Add about .020 or so under the inner pinion bearing and watch how it falls together..
Once you move the pinion out some the back lash will setup much better..
Also its hard to see a good pattern cause there isnt much load on the gears. Have a friend hold a wrench on a ring gear bolt and you turn the pinion with the breaker bar. Tell him to try and stop you from moving the gears...
The pattern will look much better.
Re: Ring & Pinion pattern help needed PLEASE! [Re: Bob_Coomer] #513953
11/02/09 11:03 PM
11/02/09 11:03 PM
Erda, UT
Erda, UT
Currently at:
Drive side
Coast side
I must be misunderstanding what you're saying... I already have the carrier shifted way to the driver's side (away from the pinion). If I add more pinion shim, it will decrease my backlash and require even more offset to get my backlash back.
Pulling pinion shim out and moving the pinion away from the axles seems to be bringing the pattern back. I'm going to go out and take another .010" out of the pinion and see what happens.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513954
11/02/09 11:34 PM
11/02/09 11:34 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
It doesn't matter how much carrier shims you use per side. You need to keep the backlash at its setting as you change the pinion shim. The only thing that matters is the pattern.
Re: Ring & Pinion pattern help needed PLEASE! [Re: bigtimeauto] #513955
11/03/09 12:08 AM
11/03/09 12:08 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You have PM
Re: Ring & Pinion pattern help needed PLEASE! [Re: Bob_Coomer] #513956
11/03/09 12:53 AM
11/03/09 12:53 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Pulling the pinion out .010" should get it close. BTW, I've always been able to get a nice pattern with Strange gears, either US Gear or the Motives. Not always that way with the off brand stuff.
Re: Ring & Pinion pattern help needed PLEASE! [Re: CMcAllister] #513957
11/03/09 01:18 AM
11/03/09 01:18 AM
Erda, UT
Erda, UT
Attempt 18 - Back pinion out .005". Resulted in slightly improved pattern and slightly more backlash. Needs more in this direction. No pics.
Attempt 19 - Back pinion out .010. Resulted in backlash increasing to .017"
Drive
Coast
Attempt 20 - Swap carrier shims by .015 to move carrier in towards pinion. Resulted in backlash reducing to .004". Too far
Drive
Coast
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513958
11/03/09 02:01 AM
11/03/09 02:01 AM
Cab_Burge Online work
Cab_Burge  Online Work
Don't we love setting up Dana spicer rear ends, especially the Dana 60 Do you have a set of set up bearings? If not get some I remember paying Bob Lambeck $75.00 to set the gears up in my Dana for the four speed Hemi Cuda, best money ever spent I charge $150.00 now and it still takes 8 hrs+ to do one usually
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513959
11/03/09 02:03 AM
11/03/09 02:03 AM
Erda, UT
Erda, UT
What do you think about the backlash? Take care of it with the carrier, or move the pinion out a bit? .004 seems a bit tight. Should I shoot for the usual .008 - .012?
Re: Ring & Pinion pattern help needed PLEASE! [Re: Cab_Burge] #513960
11/03/09 02:05 AM
11/03/09 02:05 AM
Erda, UT
Erda, UT
I was just over ar Bob's shop a few hours ago... He's rebuilding the 427 for the '69 Stingray I'm restoring for my Mom.
No, I don't have setup beaings. Just a 40 ton press and a splitter.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513961
11/03/09 02:15 AM
11/03/09 02:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Got a couple extra inner races... Got a brake hone.. Then you have set-up bearings... It will be so worth it... 8.75 is so much easier... Back when I was doing Dana's I fabbed a spreader out of some pieces of .5x1.5 flat bar & a big turn buckle.. Just don't over do it with the turn buckle...
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513962
11/03/09 02:20 AM
11/03/09 02:20 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Oh man...Dan I've got dana 60 setup bearings I can send you if you want them (sounds like it may be too late though)..Let me know.
It took me 21 hours to rebuild my Dana 60 start to finish (including making setup bearings, etc)...lol..I'm slow. But I had no press and homemade tools which sure made it interesting.
Re: Ring & Pinion pattern help needed PLEASE! [Re: Quicksilver440] #513963
11/03/09 02:24 AM
11/03/09 02:24 AM
Erda, UT
Erda, UT
I'm getting pretty fast... About 15 minutes to remove the carrier, swap shims, reinstall and check. 10 minutes to pull the pinion, reset shims and reinstal. lI'm close, but I'm torn whether to move the carrier or back the pinion out. I think I should move the carrier about .005 away from the pinion to get my backlash back up. .004 lash seems too tight, but the pattern is starting to look good.
