Ring & Pinion pattern. I'm stumped. Measured it.
#513944
11/02/09 02:16 AM
11/02/09 02:16 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
17 attempts and counting... Currently at: .0195" shim behind driver side carrier bearing .098" shim behind passenger side carrier bearing .060" shim behind the big pinion bearing cup .076" shim between the pinion and small bearing Backlash is at .009" Pinion free spin torque is about 3 inch pounds w/o seal. I'll be removing a few .001's from the preload shim pack to bring that up. These are new Strange gears and Timken bearings. It looks to me like it might need some more pinion shim to bring the pinion closer to the axles. What says the hive mind? How much of what? Drive side Coast side![](http://img.photobucket.com/albums/v227/67Charger/IMG_3817-1.jpg)
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Ring & Pinion pattern help needed PLEASE!
[Re: 67Charger]
#513945
11/02/09 08:18 AM
11/02/09 08:18 AM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Are you using a case spreader? Try moving the carrier .003 closer to the pinion. Where its at right now ain`t that bad. ![](/ubbthreads/images/graemlins/Twocents.gif) A perfect pattern is`nt easy to get ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#513946
11/02/09 09:42 AM
11/02/09 09:42 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
the pinion is to close to the carrier needs to be moved out. remove pinion shim.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#513948
11/02/09 09:49 AM
11/02/09 09:49 AM
Posts: 877 ky
68roadrunner
ky
move the pinion away from carrier, and you will see the drive and coast marks start to move across from each other.
[Re: 6bblFLASH]
#513949
11/02/09 10:43 AM
11/02/09 10:43 AM
67Charger
Erda, UT
The previous setup attempt was with the carrier shimmed .006 closer to the pinion, which gave me .004 backlash and about the same pattern. I'm going to pull some pinion shim and try gain... I kept moving the pinion deeper when I was getting marks on the drive toe and coast heel. My backlash was off too, so I never saw a perfect pattern, but the marks did swap sides to drive - center, coast - toe. I guess I passed it.
I don't have a case spreader, but I have about .010" more shim in there than I can force the carrier in by hand with. I use a rubber mallet to drive it in, and it has some decent drag to it when free-spinning.
[Re: 67Charger]
#513950
11/02/09 02:52 PM
11/02/09 02:52 PM
67Charger
Erda, UT
-.005" pinion shim helped some, but not enough. I would venture to say about .010" more out and I'd be closer.
I'll try it and post it up after work.
[Re: Bob_Coomer]
#513953
11/02/09 11:03 PM
11/02/09 11:03 PM
67Charger
Erda, UT
Currently at:
Drive side
Coast side
All that shim on one side is telling you dont have enough shim under the inner pinion bearing.. You need to move the pinion out toward the ring gear.. Add about .020 or so under the inner pinion bearing and watch how it falls together.. Once you move the pinion out some the back lash will setup much better..
Also its hard to see a good pattern cause there isnt much load on the gears. Have a friend hold a wrench on a ring gear bolt and you turn the pinion with the breaker bar. Tell him to try and stop you from moving the gears... The pattern will look much better.
I must be misunderstanding what you're saying... I already have the carrier shifted way to the driver's side (away from the pinion). If I add more pinion shim, it will decrease my backlash and require even more offset to get my backlash back.
Pulling pinion shim out and moving the pinion away from the axles seems to be bringing the pattern back. I'm going to go out and take another .010" out of the pinion and see what happens.
[Re: 67Charger]
#513954
11/02/09 11:34 PM
11/02/09 11:34 PM
bigtimeauto
Trophy Winner
Trophy Winner
It doesn't matter how much carrier shims you use per side. You need to keep the backlash at its setting as you change the pinion shim. The only thing that matters is the pattern.
[Re: Bob_Coomer]
#513956
11/03/09 12:53 AM
11/03/09 12:53 AM
Posts: 11,705 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pulling the pinion out .010" should get it close. BTW, I've always been able to get a nice pattern with Strange gears, either US Gear or the Motives. Not always that way with the off brand stuff.
[Re: CMcAllister]
#513957
11/03/09 01:18 AM
11/03/09 01:18 AM
67Charger
Erda, UT
Attempt 18 - Back pinion out .005". Resulted in slightly improved pattern and slightly more backlash. Needs more in this direction. No pics. Attempt 19 - Back pinion out .010. Resulted in backlash increasing to .017" Drive ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3818.jpg) Coast Attempt 20 - Swap carrier shims by .015 to move carrier in towards pinion. Resulted in backlash reducing to .004". Too far ![](/ubbthreads/images/graemlins/flame.gif) Drive ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3820.jpg) Coast ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3822.jpg)
[Re: 67Charger]
#513958
11/03/09 02:01 AM
11/03/09 02:01 AM
Posts: 43,300 Bend,OR USA
Cab_Burge
Don't we love setting up Dana spicer rear ends, especially the Dana 60 ![](/ubbthreads/images/graemlins/whistling.gif) Do you have a set of set up bearings? If not get some ![](/ubbthreads/images/graemlins/thumbs.gif) I remember paying Bob Lambeck $75.00 to set the gears up in my Dana for the four speed Hemi Cuda, best money ever spent ![](/ubbthreads/images/graemlins/thumbs.gif) I charge $150.00 now and it still takes 8 hrs+ to do one usually ![](/ubbthreads/images/graemlins/rant.gif)
[Re: 67Charger]
#513959
11/03/09 02:03 AM
11/03/09 02:03 AM
67Charger
Erda, UT
What do you think about the backlash? Take care of it with the carrier, or move the pinion out a bit? .004 seems a bit tight. Should I shoot for the usual .008 - .012?
[Re: Cab_Burge]
#513960
11/03/09 02:05 AM
11/03/09 02:05 AM
67Charger
Erda, UT
Don't we love setting up Dana spicer rear ends, especially the Dana 60 Do you have a set of set up bearings? If not get some I remember paying Bob Lambeck $75.00 to set the gears up in my Dana for the four speed Hemi Cuda, best money ever spent I charge $150.00 now and it still takes 8 hrs+ to do one usually
I was just over ar Bob's shop a few hours ago... He's rebuilding the 427 for the '69 Stingray I'm restoring for my Mom.
No, I don't have setup beaings. Just a 40 ton press and a splitter.
[Re: Quicksilver440]
#513963
11/03/09 02:24 AM
11/03/09 02:24 AM
67Charger
Erda, UT
I'm getting pretty fast... About 15 minutes to remove the carrier, swap shims, reinstall and check. 10 minutes to pull the pinion, reset shims and reinstal. lI'm close, but I'm torn whether to move the carrier or back the pinion out. I think I should move the carrier about .005 away from the pinion to get my backlash back up. .004 lash seems too tight, but the pattern is starting to look good.
