Will a bad ammeter make my lights flicker? #508571
10/26/09 09:45 PM
10/26/09 09:45 PM
Seattle Wa
PowerWagonDude Offline OP
Seattle Wa
My headlights in my 75 D300 flicker bright and dim and my heater does the same thing at random times. I replaced the voltage regulator and it is charging. I looked for bare wires and taped up worn ones. Could it be my ammeter?
Re: Will a bad ammeter make my lights flicker? [Re: PowerWagonDude] #508572
10/26/09 09:52 PM
10/26/09 09:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not unless the wires on it are loose. I would suspect the bulhead connectors.
Re: Will a bad ammeter make my lights flicker? [Re: stumpy] #508573
10/26/09 11:45 PM
10/26/09 11:45 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
although thats a tipical Mopar simpthom by default, is increased by the bulkhead conection damages and loosen wires at ammeter, but not realy by the ammeter itself
( unless studs inside ammeter are loosen too from inside )
Re: Will a bad ammeter make my lights flicker? [Re: PowerWagonDude] #508574
10/26/09 11:47 PM
10/26/09 11:47 PM
clean every electrical connection in sight & everyone that isn't.
Re: Will a bad ammeter make my lights flicker? [Re: RapidRobert] #508575
10/27/09 12:11 AM
10/27/09 12:11 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
and replace your damaged wires with new ones. taping over them did nothing but "hide" the problem! old wires with insulation that's cracked and fallen off will also have corroded copper under whats left of the insulation. the resistance will be higher, so you will get less voltage flowing through them, and what flow you DO get, will cause excessive heating, causing further damages, up to and including catastrophic electrical fires
**Photobucket sucks**
Re: Will a bad ammeter make my lights flicker? [Re: 70Cuda383] #508576
10/27/09 01:14 AM
10/27/09 01:14 AM
Do the madd bypass but at least run a heavy wire from the alt+ to the bat+ with a fuselink in it. Check and reinforce your grounds.
