Re: Will a bad ammeter make my lights flicker?
[Re: stumpy]
#508573
10/26/09 11:45 PM
10/26/09 11:45 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
although thats a tipical Mopar simpthom by default, is increased by the bulkhead conection damages and loosen wires at ammeter, but not realy by the ammeter itself ( unless studs inside ammeter are loosen too from inside )
[Re: PowerWagonDude]
#508574
10/26/09 11:47 PM
10/26/09 11:47 PM
RapidRobert
clean every electrical connection in sight & everyone that isn't.
[Re: 70Cuda383]
#508576
10/27/09 01:14 AM
10/27/09 01:14 AM
Do the madd bypass but at least run a heavy wire from the alt+ to the bat+ with a fuselink in it. Check and reinforce your grounds.
