How hot does your electric fuel pump get? #507442
10/25/09 09:45 PM
10/25/09 09:45 PM
Kewaskum, WI
K
Kelob_pie Offline OP
K
Kewaskum, WI
Hi guys. I have a Quickstar 275 pump, I never went for long cruises with my car yet (nothing over 20 miles at a crack, still trying to finish the car up), but even going for a five mile ride I notice that the outside of the pump gets surprisingly very, very warm to the touch. Is this normal?
Also, car pooped out today after the fuel pump stopped working. I tapped it with a rubber mallet and it started working again.
It's currently set up dead head style per Magnaflows instructions.
What do you think? How hot to the touch do yours get?
Re: How hot does your electric fuel pump get? [Re: Kelob_pie] #507443
10/25/09 11:09 PM
10/25/09 11:09 PM
car pooped out today after the fuel pump stopped working. I tapped it with a rubber mallet and it started working again. What do you think?
It's got a problem, open it up & check it out & fix it if it's fixable or replace it before it conks out for good a long ways from home.
Re: How hot does your electric fuel pump get? [Re: RapidRobert] #507444
10/26/09 07:42 AM
10/26/09 07:42 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe brushes in the motor getting hung up.
Re: How hot does your electric fuel pump get? [Re: Kelob_pie] #507445
10/26/09 08:05 AM
10/26/09 08:05 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Dead head is a very bad idea with a electric fuel pump. It needs a return line to cool the pump and prevent vapor lock, no matter what the instructions say.
Re: How hot does your electric fuel pump get? [Re: Challenger 1] #507446
10/26/09 04:41 PM
10/26/09 04:41 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
x 100
Elec pumps need constant cool fuel thru them. I've heard of some folks T'ing the return into the pump inlet, and this works to some extent. But you'll always be sending hot fuel thru the pump that way (especially at idle when bypass fule volume is highest) and the situation will be worse the higher your pump capacity is.
IMHO, teh folks that T back into pump inlet might be fine for driving around town, but I wonder how many of them go on a road trip and kill their pump?
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: How hot does your electric fuel pump get? [Re: Fury Fan] #507447
10/26/09 09:27 PM
10/26/09 09:27 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what about a pump like this? the fuel flows through the bottom base plate, and not through or around the electric motor to cool it down, how much cooling will you get by running a return system on a pump like this?
I've had mine set-up dead head style for 2 years now, 4,000 street miles, to include a road trip from Columbus to Pittsburgh--3.5 hours 1 way.
**Photobucket sucks**
Re: How hot does your electric fuel pump get? [Re: 70Cuda383] #507448
10/26/09 09:37 PM
10/26/09 09:37 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
99 corvette fuel filter has a third line wich is used as a return line for unneeded fuel to return back to the tank. It is a fairly easy change over, depending on your fittings.
DRIVE EM, DONT HIDE EM.
Re: How hot does your electric fuel pump get? [Re: Kelob_pie] #507449
10/26/09 10:46 PM
10/26/09 10:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Without a return line the pump is overworking unless you're running the motor at WOT. For anything other than a race car you need a return line.
As for using the fuel to cool the pump and then send the hot fuel on to the carb , well, that wouldn't be my preference!!
Re: How hot does your electric fuel pump get? [Re: Stanton] #507450
10/27/09 12:40 AM
10/27/09 12:40 AM
Kewaskum, WI
K
K
Kewaskum, WI
The setup I have has a pump and filter in one unit. It has an external bypass (after the pump) that runs back into the tank. I'm sorry, maybe it's not a dead head? That's what some guy that saw my setup told me. Don't know that much about the fuel sytem stuff.
Re: How hot does your electric fuel pump get? [Re: Kelob_pie] #507451
10/27/09 09:29 AM
10/27/09 09:29 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Is the bypass pressure adjustable? Maybe its set too high.
Re: How hot does your electric fuel pump get? [Re: Stanton] #507452
10/27/09 01:40 PM
10/27/09 01:40 PM
Kewaskum, WI
K
K
Kewaskum, WI
The bypass is fixed at 18 PSI I believe. It is not adjustable.
Re: How hot does your electric fuel pump get? [Re: Kelob_pie] #507453
10/27/09 03:24 PM
10/27/09 03:24 PM
oregon
ramcharger1964 Offline
oregon
18 seems WAY high to me. I run my 500 CI max wedge at 9 psi with the motor off and 6 while it is running.........
Hell B!tch Racing Co.
