which electric water pump do you prefer ? #502785
10/21/09 12:39 PM
10/21/09 12:39 PM
Wi.
65_gt_rag_402 Offline OP
Wi.
Which electic water pump are you guys using on your small blocks ? Also , what kind of gains by using one? I have a mopar clutch fan on mine now.
Always looking for a little more HP .
Any pictures of your set ups also .
How about electric fans ... what are you guys using there ? I'd probally need a pusher style.
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: which electric water pump do you prefer ? [Re: 65_gt_rag_402] #502786
10/21/09 01:00 PM
10/21/09 01:00 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Cvr 55gpm
Mopar Performance
Re: which electric water pump do you prefer ? [Re: moparniac] #502787
10/21/09 01:23 PM
10/21/09 01:23 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I have had the CSR (CSI) pump on my car for 6 years now with no issues.
Re: which electric water pump do you prefer ? [Re: ajcasini] #502788
10/21/09 02:12 PM
10/21/09 02:12 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Have a Moroso on my Mom's Duster 360, and a CSI on my 422. Both work great. I think going from a fan and pump to a electric pump is good for .10 in the 1/8th.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: which electric water pump do you prefer ? [Re: Jacob Pitt] #502789
10/21/09 02:21 PM
10/21/09 02:21 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
CSR here.. Love it..
Re: which electric water pump do you prefer ? [Re: Jacob Pitt] #502790
10/21/09 03:17 PM
10/21/09 03:17 PM
Wi.
Wi.
I've been reading that the moroso does not stick out as far towards the radiator as the CSR one does.
Is that correct and how much is the difference ?
I'd probally have clearance problems.
Re: which electric water pump do you prefer ? [Re: 65_gt_rag_402] #502791
10/21/09 03:21 PM
10/21/09 03:21 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Me and my brother both saw right at a 1/10 swapping to an electric pump and fan
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: which electric water pump do you prefer ? [Re: 65_gt_rag_402] #502792
10/21/09 03:35 PM
10/21/09 03:35 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Don't forget about good fans, something with 2000 plus CFM.
Re: which electric water pump do you prefer ? [Re: 68Fastback] #502793
10/21/09 04:02 PM
10/21/09 04:02 PM
an8sec70cuda Offline
Meziere on my Hemi. Works great. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: which electric water pump do you prefer ? [Re: 65_gt_rag_402] #502794
10/21/09 04:47 PM
10/21/09 04:47 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
I still use the stocker run by a Moroso electric motor, for simplicity sake.
Think about it, the motor goes out you have another one in the trailer. Bolt it on and continue to race. I you have a Meziere or something and it goes out, you go home.
I'm a simple man.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: which electric water pump do you prefer ? [Re: Steve1118] #502795
10/21/09 08:42 PM
10/21/09 08:42 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We run the Moroso units and have never had any problems.
Nothing wrong at all with simplicity...we still use a Mopar tach drive distributor and Stewart Warner gauges,along with other old stuff.If it works,why get rid of it???
Nautilus Racing-
Re: which electric water pump do you prefer ? [Re: Chris2581] #502796
10/21/09 08:42 PM
10/21/09 08:42 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I am running the Moroso also so far no problems
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: which electric water pump do you prefer ? [Re: 65_gt_rag_402] #502797
10/21/09 09:07 PM
10/21/09 09:07 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
I run the Moroso too.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: which electric water pump do you prefer ? [Re: Cudahlr] #502798
10/21/09 09:11 PM
10/21/09 09:11 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Here's another pic.
Re: which electric water pump do you prefer ? [Re: Cudahlr] #502799
10/21/09 10:06 PM
10/21/09 10:06 PM
alabama
mopars rule Offline
mopar addict
mopars rule  Offline
mopar addict
alabama
I think the Moroso unit is 1" shorter than the CSR.
Re: which electric water pump do you prefer ? [Re: mopars rule] #502800
10/21/09 10:18 PM
10/21/09 10:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You would be surprised on the people running the Moroso water pump drive kit.
I know I was floored when I seen Bob Reed's Cuda have one.
Like someone else said they are simple and do the job.
I have run the Meziere drop in unit for a big block. I ran that water pump season after season..It was one if the few things that you can install on a race car and absolutely forget maintenance or trouble.
But Now I dont have a aluminum water pump housing or water pump...So getting both of these and then add in the cost of the Moroso drive..Im looking at the complete Meziere unit cost wise.
Re: which electric water pump do you prefer ? [Re: Bob_Coomer] #502801
10/21/09 10:36 PM
10/21/09 10:36 PM
Roseau, MN
1976 Aspen Offline
1976 Aspen  Offline
Roseau, MN
Well, I have had a Moroso unit for the past two years. The first thing that happened was the set screws from the motor to the impeller came loose and the impeller quit turning. That was a wasted weekend of racing. My buddy's Moroso did the exact same thing and they were bought at the same time. Last race of the year three weeks ago my pump decides to quit almost costing me the championship. I swapped over to a mechanical for the day and ran like that. And guess who's pump went out within the next day... yup, my buddy's... My buddy is getting his replaced for free because it was less than a year since the first replacement. I had to pay $44 for parts & Labor to fix mine which isn't bad... Are we the only unlucky people having problems with these pumps???
Whatcha think StrokerDart??? Can we be that unlucky???
Re: which electric water pump do you prefer ? [Re: 1976 Aspen] #502802
10/22/09 04:43 AM
10/22/09 04:43 AM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
I have a Meziere on one car and a CSR on the other.
Both beat a stock pump by far but the Meziere is a much better pump.
Why does divorce cost so much? Because it is worth it!!!!!
Re: which electric water pump do you prefer ? [Re: 1976 Aspen] #502803
10/22/09 10:06 AM
10/22/09 10:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have always had good luck with Meziere.
Re: which electric water pump do you prefer ? [Re: 1976 Aspen] #502804
10/22/09 01:35 PM
10/22/09 01:35 PM
Winnipeg, Canada
StrokerDart Offline
StrokerDart  Offline
Winnipeg, Canada
Seems uncanny that we'd have three pumps go on us... each time only lasting months of use ... but maybe we just hit a bad batch . BTW The repair guy at Moroso said my most recent one they found the hole the impeller shaft rides in was too shallow by a fraction of an inch... I bitched about the set screws coming loose and that I think that is the root cause of the pumps eventually failing electrically...
He assures me we should be good now and that the set screw "issue" will be looked after on the repairs (as well as for future ones on the assembly line I suupose)
I definitely like the Moroso from a design perspective ... makes it easy to rig an alternator in the stock location using the stock alt brackets. All we needed to do was make correct length bushings for the two (long) bolts holding alt brackets to the water pump.
I think a spare in the trailer might be a good idea anyway though.
