which electric water pump do you prefer ?
#502785
10/21/09 12:39 PM
10/21/09 12:39 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
Which electic water pump are you guys using on your small blocks ? Also , what kind of gains by using one? I have a mopar clutch fan on mine now. Always looking for a little more HP . Any pictures of your set ups also . How about electric fans ... what are you guys using there ? I'd probally need a pusher style.
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!!
11.0's on pump gas .
Re: which electric water pump do you prefer ?
[Re: ajcasini]
#502788
10/21/09 02:12 PM
10/21/09 02:12 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Have a Moroso on my Mom's Duster 360, and a CSI on my 422. Both work great. I think going from a fan and pump to a electric pump is good for .10 in the 1/8th.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#502790
10/21/09 03:17 PM
10/21/09 03:17 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
I've been reading that the moroso does not stick out as far towards the radiator as the CSR one does. Is that correct and how much is the difference ? I'd probally have clearance problems.
[Re: 68Fastback]
#502793
10/21/09 04:02 PM
10/21/09 04:02 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Meziere on my Hemi. Works great. CHIP
[Re: 65_gt_rag_402]
#502794
10/21/09 04:47 PM
10/21/09 04:47 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
I still use the stocker run by a Moroso electric motor, for simplicity sake.
Think about it, the motor goes out you have another one in the trailer. Bolt it on and continue to race. I you have a Meziere or something and it goes out, you go home.
I'm a simple man.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Chris2581]
#502796
10/21/09 08:42 PM
10/21/09 08:42 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I am running the Moroso also so far no problems
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: mopars rule]
#502800
10/21/09 10:18 PM
10/21/09 10:18 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
You would be surprised on the people running the Moroso water pump drive kit. I know I was floored when I seen Bob Reed's Cuda have one. Like someone else said they are simple and do the job. I have run the Meziere drop in unit for a big block. I ran that water pump season after season..It was one if the few things that you can install on a race car and absolutely forget maintenance or trouble. But Now I dont have a aluminum water pump housing or water pump...So getting both of these and then add in the cost of the Moroso drive..Im looking at the complete Meziere unit cost wise.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 1976 Aspen]
#502802
10/22/09 04:43 AM
10/22/09 04:43 AM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I have a Meziere on one car and a CSR on the other. Both beat a stock pump by far but the Meziere is a much better pump.
Why does divorce cost so much?
Because it is worth it!!!!!
[Re: 1976 Aspen]
#502803
10/22/09 10:06 AM
10/22/09 10:06 AM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
I have always had good luck with Meziere.
[Re: 1976 Aspen]
#502804
10/22/09 01:35 PM
10/22/09 01:35 PM
Posts: 100 Winnipeg, Canada
StrokerDart
Winnipeg, Canada
Well, I have had a Moroso unit for the past two years. The first thing that happened was the set screws from the motor to the impeller came loose and the impeller quit turning. That was a wasted weekend of racing. My buddy's Moroso did the exact same thing and they were bought at the same time. Last race of the year three weeks ago my pump decides to quit almost costing me the championship. I swapped over to a mechanical for the day and ran like that. And guess who's pump went out within the next day... yup, my buddy's... My buddy is getting his replaced for free because it was less than a year since the first replacement. I had to pay $44 for parts & Labor to fix mine which isn't bad... Are we the only unlucky people having problems with these pumps???
Whatcha think StrokerDart??? Can we be that unlucky???
Seems uncanny that we'd have three pumps go on us... each time only lasting months of use ... but maybe we just hit a bad batch . BTW The repair guy at Moroso said my most recent one they found the hole the impeller shaft rides in was too shallow by a fraction of an inch... I bitched about the set screws coming loose and that I think that is the root cause of the pumps eventually failing electrically... He assures me we should be good now and that the set screw "issue" will be looked after on the repairs (as well as for future ones on the assembly line I suupose)
I definitely like the Moroso from a design perspective ... makes it easy to rig an alternator in the stock location using the stock alt brackets. All we needed to do was make correct length bushings for the two (long) bolts holding alt brackets to the water pump.
I think a spare in the trailer might be a good idea anyway though.
