727 Front tranny seal....... #498944
10/16/09 07:10 PM
10/16/09 07:10 PM
Boswell, PA
67PLY Offline OP
67PLY  Offline OP
Boswell, PA
How hard is it to replace the front pump/converter seal while the 727 is still in the car/truck? Engine is being pulled for a swap.
Re: 727 Front tranny seal....... [Re: 67PLY] #498945
10/16/09 07:12 PM
10/16/09 07:12 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
easier then riding a bike, pop it out make sure everything is clean and reinstall new one
Re: 727 Front tranny seal....... [Re: 67PLY] #498946
10/16/09 07:18 PM
10/16/09 07:18 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
It's easy once the engine is out , BUT, the convertor can be a PITA to get out sometimes.
Would it not be easier to just the pull the engine and tranny together and put them back in together?
Re: 727 Front tranny seal....... [Re: JoesMopar] #498947
10/16/09 07:25 PM
10/16/09 07:25 PM
Boswell, PA
67PLY Offline OP
67PLY  Offline OP
Boswell, PA
It's in an '84 Power Ram 4x4 truck.....the transfer case is attached the tranny.
Re: 727 Front tranny seal....... [Re: JoesMopar] #498948
10/16/09 07:26 PM
10/16/09 07:26 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Piece of cake. Only tricky part is removal of existing seal.
Re: 727 Front tranny seal....... [Re: 67PLY] #498949
10/17/09 04:44 PM
10/17/09 04:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
After driving the new seal in, shine a flashlight in the hole to make sure the garter spring didn't pop off of the seal.
Re: 727 Front tranny seal....... [Re: JoesMopar] #498950
10/17/09 04:49 PM
10/17/09 04:49 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If the convertor is hard to remove you have other issues to deal with besides a leaky seal
