rebuilt 4 speed 833 question #497318
10/14/09 07:45 PM
10/14/09 07:45 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
I purchased a rebuilt 4 speed to install in the 62 dodge. I won't be using it for a year or two because I'm restoring the car. Should I put fluid in it or just leave it dry while it sits on the shelf for the next year or two. Thanks, Alex
I finally got a picture of my neon sign on here thanks to my daughter.
Re: rebuilt 4 speed 833 question [Re: Alexdodge] #497319
10/14/09 07:57 PM
10/14/09 07:57 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Put some fluid in and spin it over to lube everything. ATF would do the trick.
Re: rebuilt 4 speed 833 question [Re: Stanton] #497320
10/14/09 10:27 PM
10/14/09 10:27 PM
Eastern ohio
Eastern ohio
What type of fluid is normally used in the A833?
And how much?
Re: rebuilt 4 speed 833 question [Re: Alexdodge] #497321
10/15/09 05:51 AM
10/15/09 05:51 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Fill it just below the fill hole. I use 80/90 gear oil.
Re: rebuilt 4 speed 833 question [Re: Pntastar69] #497322
10/15/09 10:29 AM
10/15/09 10:29 AM
And get a tailshaft plug.
Re: rebuilt 4 speed 833 question #497323
10/15/09 06:55 PM
10/15/09 06:55 PM
Eastern ohio
Eastern ohio
Tailshaft plug??? You mean its going to run out if I don't plug the tailshaft? What type of plug do I need?
Re: rebuilt 4 speed 833 question [Re: Alexdodge] #497324
10/15/09 08:55 PM
10/15/09 08:55 PM
ohio
B5 GTX Offline
B5 GTX  Offline
ohio
An old slip yolk is best, just make sure it is clean.
scott
Re: rebuilt 4 speed 833 question [Re: B5 GTX] #497325
10/16/09 10:19 AM
10/16/09 10:19 AM
Eastern ohio
Eastern ohio
I'll do that! Thanks all.
