SB Motor plate #496909
10/14/09 08:25 AM
10/14/09 08:25 AM
412 SB Duster Offline OP
Who's SB Motor plate do you recommend. I what one that looks good as well.
Al
Re: SB Motor plate [Re: 412 SB Duster] #496910
10/14/09 08:55 AM
10/14/09 08:55 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
here's mine I got from NHRAMark....
Re: SB Motor plate [Re: dc426] #496911
10/14/09 10:47 AM
10/14/09 10:47 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Al
Mark helped with the MMW race thier website is aeicnc.com .
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: SB Motor plate [Re: 10 o to go] #496912
10/14/09 12:43 PM
10/14/09 12:43 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
Nice piece Mark has...on my wish list also.
http://www.aeicnc.com/sbdpro36.html
Re: SB Motor plate [Re: ETASPEN] #496913
10/14/09 01:55 PM
10/14/09 01:55 PM
Thanks guys, I'll get in touch with Mark. I need to get it setup before I pull the motor.
Thanks again
Al
Re: SB Motor plate [Re: 412 SB Duster] #496914
10/14/09 02:32 PM
10/14/09 02:32 PM
Winnipeg, Canada
StrokerDart Offline
StrokerDart  Offline
Winnipeg, Canada
What do you guys use for an engine limiter (for/aft movement) in these A-bodies when you put in a motor plate ??
Re: SB Motor plate [Re: StrokerDart] #496915
10/15/09 09:46 AM
10/15/09 09:46 AM
Winnipeg, Canada
StrokerDart Offline
StrokerDart  Offline
Winnipeg, Canada
...or if you use a 3/8" think plate, is a limiter just not needed ???
(sorry for hijacking this post)
thanks guys!
Re: SB Motor plate [Re: StrokerDart] #496916
10/16/09 07:53 AM
10/16/09 07:53 AM
Roseau, MN
1976 Aspen Offline
1976 Aspen  Offline
Roseau, MN
SOmething has to limit the fore/aft movement on??? Any pics or info guys???
Re: SB Motor plate [Re: StrokerDart] #496917
10/16/09 08:27 AM
10/16/09 08:27 AM
Out West
408strokerdart Offline
Out West
thanks guys!
3/8" plate helps, but plate is not very strong in that direction (thin cros section). You still need a limiter. I only have one and it comes from a bracket that I made to attach to the original motor mount locations on the block down to a clevis bracket welded to the k-frame. I don't have pic's on my work computer to share. Good luck.
Re: SB Motor plate [Re: 408strokerdart] #496918
10/16/09 12:06 PM
10/16/09 12:06 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Al, why are you going to a motor plate???
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: SB Motor plate [Re: B3422W5] #496919
10/16/09 01:04 PM
10/16/09 01:04 PM
Looking to remove some weight off the front end. Going to make a new K member.
Al
Re: SB Motor plate [Re: 412 SB Duster] #496920
10/16/09 01:05 PM
10/16/09 01:05 PM
Portage,michigan
Portage,michigan
Al
1.41 best 60 foot
6.60 at 103.90 1/8
