Re: SB Motor plate
[Re: dc426]
#496911
10/14/09 10:47 AM
10/14/09 10:47 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Al Mark helped with the MMW race thier website is aeicnc.com . don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
Re: SB Motor plate
[Re: StrokerDart]
#496915
10/15/09 09:46 AM
10/15/09 09:46 AM
Posts: 100 Winnipeg, Canada
StrokerDart
Winnipeg, Canada
What do you guys use for an engine limiter (for/aft movement) in these A-bodies when you put in a motor plate ??
...or if you use a 3/8" think plate, is a limiter just not needed ???
(sorry for hijacking this post) thanks guys!
Re: SB Motor plate
[Re: StrokerDart]
#496917
10/16/09 08:27 AM
10/16/09 08:27 AM
Posts: 3,456 Out West
408strokerdart
Out West
3/8" plate helps, but plate is not very strong in that direction (thin cros section). You still need a limiter. I only have one and it comes from a bracket that I made to attach to the original motor mount locations on the block down to a clevis bracket welded to the k-frame. I don't have pic's on my work computer to share. Good luck.
Re: SB Motor plate
[Re: 408strokerdart]
#496918
10/16/09 12:06 PM
10/16/09 12:06 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Al, why are you going to a motor plate???
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
