E body left front frame rail..same as 70-71 B body? #496552
10/13/09 08:01 PM
10/13/09 08:01 PM
Austin, TX
HemiDave Offline OP
HemiDave  Offline OP
Austin, TX
Is it the 70-71 B bodies that have the same frame rails as a 74 Cuda left front frame rail?
Thanks!!
Re: E body left front frame rail..same as 70-71 B body? [Re: HemiDave] #496553
10/13/09 08:39 PM
10/13/09 08:39 PM
IMGTX Offline
IMGTX  Offline
Dimensionally they are the same but they have different part numbers so there is a difference.
I know the 70/71 cars had two bolts for the bumper mounts and the 73/74 had 3.
Re: E body left front frame rail..same as 70-71 B body? [Re: IMGTX] #496554
10/13/09 08:51 PM
10/13/09 08:51 PM
Austin, TX
HemiDave Offline OP
HemiDave  Offline OP
Austin, TX
I know there is a difference in the shock mount area but I'm not sure which are the same.....
Re: E body left front frame rail..same as 70-71 B body? [Re: HemiDave] #496555
10/14/09 06:06 PM
10/14/09 06:06 PM
Austin, TX
HemiDave Offline OP
HemiDave  Offline OP
Austin, TX
Re: E body left front frame rail..same as 70-71 B body? [Re: HemiDave] #496556
10/14/09 06:36 PM
10/14/09 06:36 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
71-72 B-body front frame rails and inner fenders are the same as 70-74 e-body (actually 70 e-body inner fenders are one year only, but the differences between 70 and 71-74 e-body inner fenders is minimal). 66-70 B-body framerails are 66-70 b-body only.
Re: E body left front frame rail..same as 70-71 B body? [Re: HemiDave] #496557
10/14/09 06:43 PM
10/14/09 06:43 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Seems to me that the 71/72 B-body cars would have more similar frame rails to the E-bodies than the 70/71 cars. IIRC, someone here was discussing the the similarity/interchangeability of other parts between the 71/72 B-bodies and the E-bodies; stuff like firewall (but not the cowl, I believe), inner fenders, and radiator yoke/crossmember. I thought that the engine bay was dimensionally the same between those two classes of cars.
But, of course, I could be out in left field...
Re: E body left front frame rail..same as 70-71 B body? [Re: MoparMarq] #496558
10/14/09 09:46 PM
10/14/09 09:46 PM
Austin, TX
HemiDave Offline OP
HemiDave  Offline OP
Austin, TX
Thanks y'all!!
71-72 it is!
Re: E body left front frame rail..same as 70-71 B body? [Re: MoparMarq] #496559
10/14/09 09:49 PM
10/14/09 09:49 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
AS mentioned above 70-72 E and 71-72 B front frame rails interchange.Shock towers are the same.Only piece different is the front rail to rocker gusset.And again as mentioned above 73-74 E rails are different 3 holes for bumper brackets.
On early B's (66-70)rear rails are specific to Dodge or Plymouth.The rear shackle pivot point is moved forward one inch on the Plymouths.Don't use Plymouth rails in Dodges and vice versa.
"Long Live Mopars"
