E body left front frame rail..same as 70-71 B body?
#496552
10/13/09 08:01 PM
10/13/09 08:01 PM
Posts: 7,497 Austin, TX
HemiDave
Austin, TX
Is it the 70-71 B bodies that have the same frame rails as a 74 Cuda left front frame rail? Thanks!! Dave
Re: E body left front frame rail..same as 70-71 B body?
[Re: HemiDave]
#496557
10/14/09 06:43 PM
10/14/09 06:43 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Seems to me that the 71/72 B-body cars would have more similar frame rails to the E-bodies than the 70/71 cars. IIRC, someone here was discussing the the similarity/interchangeability of other parts between the 71/72 B-bodies and the E-bodies; stuff like firewall (but not the cowl, I believe), inner fenders, and radiator yoke/crossmember. I thought that the engine bay was dimensionally the same between those two classes of cars.
But, of course, I could be out in left field...
[Re: MoparMarq]
#496559
10/14/09 09:49 PM
10/14/09 09:49 PM
Posts: 2,601 Great White North
Furyman
Great White North
AS mentioned above 70-72 E and 71-72 B front frame rails interchange.Shock towers are the same.Only piece different is the front rail to rocker gusset.And again as mentioned above 73-74 E rails are different 3 holes for bumper brackets. On early B's (66-70)rear rails are specific to Dodge or Plymouth.The rear shackle pivot point is moved forward one inch on the Plymouths.Don't use Plymouth rails in Dodges and vice versa.
"Long Live Mopars"
