No Tailights #493542
10/10/09 09:53 PM
10/10/09 09:53 PM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
This morning I took my RT out and whenever I touched the brake pedal the dome light went on. I checked my lights and I have no tailights or brakelights. I checked the fuse, it's okay. I checked the connectors to each tailght and no power. Any ideas? Thanks
Re: No Tailights [Re: JM67RT] #493543
10/11/09 01:47 AM
10/11/09 01:47 AM
Which connectors? I'd start w the connectors behind the drivers kick panel & jump 12V to the correct circuit for the brake lights(large filaments) and for the park lights (small filaments) & see if your good downstream & if good there jump 12V to the downstream side of the brake light switch (the white wire) & see if the correct wires in/out of the st column has continuity (for the brakes) at the steering col connector (hot in & 2 hot out to both brake lights). For the park lights pull the bakelite connector off the headlight sw & jump 12V to the park light(s) circuit & see if you have fire at the correct wire behind the kick panel. Wiring diagrams at www.mymopar.com
Re: No Tailights [Re: JM67RT] #493544
10/11/09 01:51 AM
10/11/09 01:51 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Has the car been painted? I had to run dedicated grounds after painting to get good grounding
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: No Tailights [Re: R70RUNNER] #493545
10/11/09 05:51 AM
10/11/09 05:51 AM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
Robert I'll give that a shot.
Car was painted a long time ago. If this adds anything, the turn signals work, but flashers don't work at all (even front lights).
Thanks guys.
Re: No Tailights [Re: JM67RT] #493546
10/11/09 10:50 AM
10/11/09 10:50 AM
Andrewh Offline
Andrewh  Offline
if your dome light came on, I would be checking the light switch as well.
The problem for me is I can't think of anywhere those two circuits cross.
Dome light goes to the dimmer and headlight switch. So that does go to the tail lights, but I thought the brake light circuit was split from that.
Either way, with parking lights not working either, that is where I would go.
Re: No Tailights [Re: Andrewh] #493547
10/11/09 11:04 AM
10/11/09 11:04 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Emergencies are probably a bad flasher. You have two. One for turn signals and one for emergency signals.
Re: No Tailights - update [Re: stumpy] #493548
10/11/09 11:07 PM
10/11/09 11:07 PM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
After testing all the connections I decided to try a spare headlight switch I had. Problem solved. Lights are all working again.
Thanks everyone.
Re: No Tailights - update [Re: JM67RT] #493549
10/11/09 11:16 PM
10/11/09 11:16 PM
even the brake lights
Re: No Tailights - update [Re: RapidRobert] #493550
10/12/09 01:23 PM
10/12/09 01:23 PM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
Yeah even the brakelights and the flashers! The switch was an aftermarket that I put in about 10 years ago. It looked a little cheap compared to an original. I had an original from a car I parted a few years ago. Could have also been just reseating the connectors fixed it?
