Re: No Tailights
[Re: JM67RT]
#493543
10/11/09 01:47 AM
10/11/09 01:47 AM
RapidRobert
Which connectors? I'd start w the connectors behind the drivers kick panel & jump 12V to the correct circuit for the brake lights(large filaments) and for the park lights (small filaments) & see if your good downstream & if good there jump 12V to the downstream side of the brake light switch (the white wire) & see if the correct wires in/out of the st column has continuity (for the brakes) at the steering col connector (hot in & 2 hot out to both brake lights). For the park lights pull the bakelite connector off the headlight sw & jump 12V to the park light(s) circuit & see if you have fire at the correct wire behind the kick panel. Wiring diagrams at www.mymopar.com
