fuel siphoning from the acc squirter. #490837
10/07/09 06:23 PM
10/07/09 06:23 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
while revving the motor up slowly and watching the squirter it all of a sudden start's spewing fuel from the hole's, what is the best way to fix this as I know it has to be making the car pig rich going down the track.
Re: fuel siphoning from the acc squirter. [Re: dartman366] #490838
10/07/09 06:24 PM
10/07/09 06:24 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would check the pump arm first and make sure its not to tight
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: fuel siphoning from the acc squirter. [Re: dartman366] #490839
10/07/09 06:31 PM
10/07/09 06:31 PM
Locomotion Offline
Locomotion  Offline
There should be a small, thin pointed cylinder in the squirter passage below the squirter screw. It points down to close the passage and keeps fuel from being siphoned out by vacuum. It is small enough to where it is not a restriction and is pushed up by the fuel from the accellerator pump.
Re: fuel siphoning from the acc squirter. [Re: dusturbd340W5] #490840
10/07/09 06:35 PM
10/07/09 06:35 PM
Q
Quicktree Offline
Quicktree  Offline
Q
not a lot more that can make it do that. check fuel pressure also.
Re: fuel siphoning from the acc squirter. [Re: Quicktree] #490841
10/07/09 06:44 PM
10/07/09 06:44 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If that little check valve below the squirter is not seating or sticking the venturaes and intake signal will draw fuel.Make sure it is free and clean and the squirter and gasket is seated and not leaking.
Re: fuel siphoning from the acc squirter. [Re: dartman366] #490842
10/07/09 06:50 PM
10/07/09 06:50 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
switching to the squirters with the tubes sticking into the ventury is 1 way to stop it.if you have had the carb for a while and it just started well you may have another problem.
Re: fuel siphoning from the acc squirter. [Re: Locomotion] #490843
10/07/09 07:19 PM
10/07/09 07:19 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
5 bucks says he lost the check valve .
Failing that they do make anti-pull over squirters for this reason...
Re: fuel siphoning from the acc squirter. [Re: CokeBottleKid] #490844
10/07/09 07:44 PM
10/07/09 07:44 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Check valve is in place, don't know if it has been doing this for awhile or not , this is the first time we have done this, as we were trying to locate a miss, and reved it up a little and held it there steady when it started doing it.
Re: fuel siphoning from the acc squirter. [Re: dartman366] #490845
10/08/09 04:29 PM
10/08/09 04:29 PM
Sounds like there may be a small piece of someting stuck in between the check valve and the check valve seat That or the check valve is in upside down Pointy end goes down
Re: fuel siphoning from the acc squirter. [Re: Cab_Burge] #490846
10/09/09 03:28 PM
10/09/09 03:28 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I think older holleys used a ball with a cylindrical weight stacked on top.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: fuel siphoning from the acc squirter. [Re: CJK440] #490847
10/09/09 06:40 PM
10/09/09 06:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes they did you are correct. That is the acc pump discharge check valve or ball as they call it. It lifts up when fuell is pushed up to it by the acc pump when you step on the gas. But it needs to seat when off the gas as the pump draws fuel back into its plunger circuit and it it dont seat it can draw air in also and cause a stumble. And as said it can cause fuel to siphon out. Ron
