Re: fuel siphoning from the acc squirter.
[Re: dartman366]
#490838
10/07/09 06:24 PM
10/07/09 06:24 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I would check the pump arm first and make sure its not to tight
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#490840
10/07/09 06:35 PM
10/07/09 06:35 PM
Quicktree
not a lot more that can make it do that. check fuel pressure also.
[Re: Locomotion]
#490843
10/07/09 07:19 PM
10/07/09 07:19 PM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
There should be a small, thin pointed cylinder in the squirter passage below the squirter screw. It points down to close the passage and keeps fuel from being siphoned out by vacuum. It is small enough to where it is not a restriction and is pushed up by the fuel from the accellerator pump.
5 bucks says he lost the check valve .
Failing that they do make anti-pull over squirters for this reason...
[Re: CokeBottleKid]
#490844
10/07/09 07:44 PM
10/07/09 07:44 PM
dartman366
Mt. Vernon, Ohio
Check valve is in place, don't know if it has been doing this for awhile or not , this is the first time we have done this, as we were trying to locate a miss, and reved it up a little and held it there steady when it started doing it.
[Re: Cab_Burge]
#490846
10/09/09 03:28 PM
10/09/09 03:28 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I think older holleys used a ball with a cylindrical weight stacked on top.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#490847
10/09/09 06:40 PM
10/09/09 06:40 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yes they did you are correct. That is the acc pump discharge check valve or ball as they call it. It lifts up when fuell is pushed up to it by the acc pump when you step on the gas. But it needs to seat when off the gas as the pump draws fuel back into its plunger circuit and it it dont seat it can draw air in also and cause a stumble. And as said it can cause fuel to siphon out. Ron
