Rod bearings for BME rods #490727
10/07/09 04:04 PM
10/07/09 04:04 PM
BA, OK
O
orangedustya Offline OP
O
BA, OK
Does anyone have a part number for rod bearings for small block bill miller aluminum rods. The local speed shop here says clevite doesn't make a dowelled bearing and I need bearings with the hole in the center of the rod cap.
Thanks, Brad
Re: Rod bearings for BME rods [Re: orangedustya] #490728
10/07/09 04:53 PM
10/07/09 04:53 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I'm not sure if they make one or not but in the past I've just made my own dowel holes in the bearings. The machine shop should be able to do it much more precisely that what I did. I just took a stock cap drilled out a hole where the dowel would be on the BME rods and then put the bearing in the cap and drilled it and then used de-burring tools to clean them up.
I've done this several times and never had any trouble but the machine shop should be able to do this much more accurately.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Rod bearings for BME rods [Re: WadeMetzinger] #490729
10/07/09 09:09 PM
10/07/09 09:09 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Child and Albert has the bearings last time I checked.
Re: Rod bearings for BME rods [Re: Leon441] #490730
10/07/09 09:24 PM
10/07/09 09:24 PM
i think they're out of business last i heard.
Re: Rod bearings for BME rods #490731
10/07/09 09:55 PM
10/07/09 09:55 PM
Lehigh Acres, Florida
rickstershemi Offline
I bet BME could point you in the right direction
Rickster
Re: Rod bearings for BME rods [Re: rickstershemi] #490732
10/08/09 09:21 AM
10/08/09 09:21 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Indy or one of thier dealers has them.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Rod bearings for BME rods [Re: MRMOPAR622] #490733
10/08/09 10:05 AM
10/08/09 10:05 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We take an old junk connecting rod,indicate the dowel location drill a hole the same size and use it as a template to locate and drill the bearings. You can use a old dowel holed bearing to locate the hole in the rod cap.
Re: Rod bearings for BME rods [Re: B G Racing] #490734
10/08/09 01:05 PM
10/08/09 01:05 PM
BA, OK
O
O
BA, OK
Thanks guys, I have a bunch of old rod caps but no dowelled brgs. It took me two caps but got the second one right and it worked great. Thanks for the advice.
Brad
Re: Rod bearings for BME rods [Re: orangedustya] #490735
10/08/09 01:51 PM
10/08/09 01:51 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Brad
