Re: Rod bearings for BME rods
[Re: orangedustya]
#490728
10/07/09 04:53 PM
10/07/09 04:53 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I'm not sure if they make one or not but in the past I've just made my own dowel holes in the bearings. The machine shop should be able to do it much more precisely that what I did. I just took a stock cap drilled out a hole where the dowel would be on the BME rods and then put the bearing in the cap and drilled it and then used de-burring tools to clean them up.
I've done this several times and never had any trouble but the machine shop should be able to do this much more accurately.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#490729
10/07/09 09:09 PM
10/07/09 09:09 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Child and Albert has the bearings last time I checked.
[Re: Leon441]
#490730
10/07/09 09:24 PM
10/07/09 09:24 PM
i think they're out of business last i heard.
[Re: orangedustya]
#490735
10/08/09 01:51 PM
10/08/09 01:51 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Thanks guys, I have a bunch of old rod caps but no dowelled brgs. It took me two caps but got the second one right and it worked great. Thanks for the advice. Brad
