Engine Bay wiring.... Fusible Link????? #489283
10/05/09 07:03 PM
10/05/09 07:03 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
My engine bay basicly has the forward light wiring. I am running one wire from my alt, and need to run the power wire from the starter relay to the junction block. This is normally the fusible link. I would like to run a fuse in place of this. Can anyone tell me what amp should be the cut out for this?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Engine Bay wiring.... Fusible Link????? [Re: DemonDust] #489284
10/05/09 08:37 PM
10/05/09 08:37 PM
IA
landon1 Offline
landon1  Offline
IA
painless sells several different amp ratings, but i think their harnesses come with 70 amp maxi fuse - not 100% on that, though
'71 Satellite Sebring 440
Re: Engine Bay wiring.... Fusible Link????? [Re: landon1] #489285
10/05/09 08:57 PM
10/05/09 08:57 PM
Illinois
493_Scamp Offline
super gas
493_Scamp  Offline
super gas
Illinois
You might check out some of the OEM solutions like the very large bolt on fusable links ford uses on trucks or the resetable circuit breakers used on wreckers\trailer packages. Much easier to reset after finding the short and make the next round. Ive seen them in 200 amps capacity.
Re: Engine Bay wiring.... Fusible Link????? [Re: DemonDust] #489286
10/05/09 10:44 PM
10/05/09 10:44 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
60-100a depending on your load and charging capacity.
I had a Maxifuse crack across element once, get to 6200 rpm and it stopped charging. I chased my tail on that one for over a year.
Go with a fusible link. I got mine from a junkyard GM wiring loom.
8.30's @3400 lbs
Re: Engine Bay wiring.... Fusible Link????? [Re: Mike Swann] #489287
10/06/09 12:31 AM
10/06/09 12:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I put my battery in the trunk I ran my main hot feed from the battery on a 10 gauge wire right from the battery to my starter relay and I used a 60 amp cartridge type fuse for my fusible link. I have just all the stock items on my 63 and I added the Mopar electronic ign , electric fuel pump and the electric fan that I just added a few months ago. Other then that it is just a stock 63 wire harness setup. I use a stock 55 amp alternator and everything has worked fine since 2006 when I go it on the road. I carry an extra 60 amp cartridge type fuse just in case but have never needed it. Ron
Re: Engine Bay wiring.... Fusible Link????? [Re: 383man] #489288
10/06/09 01:44 AM
10/06/09 01:44 AM
How many amps does the starter, electric fuel, water pump, fan and ignition draw when all of them are on? Find that out and add a safe margin like 25 amps or a little more
Re: Engine Bay wiring.... Fusible Link????? [Re: Cab_Burge] #489289
10/06/09 01:55 AM
10/06/09 01:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Think you may want to eliminate the starter from that circuit. Ron
Re: Engine Bay wiring.... Fusible Link????? [Re: 383man] #489290
10/06/09 02:02 AM
10/06/09 02:02 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
FYI, 10 awg is rated for 35a. You'll never get to 60a, except in SC condition.
8.30's @3400 lbs
Re: Engine Bay wiring.... Fusible Link????? [Re: landon1] #489291
10/06/09 11:25 AM
10/06/09 11:25 AM
Menomonee Falls
Menomonee Falls
I'm actually looking to just run the headlights, signals, msd, and gauges inside the car, with this wire. The fan, will be on a separate circuit.
I have the factory fusible link, but i don't want to burn it up and have to replace it. I'd rather replace a fuse or reset a breaker.
SDG Motorsports
Re: Engine Bay wiring.... Fusible Link????? [Re: Mike Swann] #489292
10/06/09 12:18 PM
10/06/09 12:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The factory used 10 gauge alot on the older cars (60's & 70's) alt wires to the amp meter and battery. Ron
