Re: Engine Bay wiring.... Fusible Link?????
[Re: DemonDust]
#489284
10/05/09 08:37 PM
10/05/09 08:37 PM
Posts: 565 IA
landon1
IA
painless sells several different amp ratings, but i think their harnesses come with 70 amp maxi fuse - not 100% on that, though
'71 Satellite Sebring 440
[Re: DemonDust]
#489286
10/05/09 10:44 PM
10/05/09 10:44 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
60-100a depending on your load and charging capacity.
I had a Maxifuse crack across element once, get to 6200 rpm and it stopped charging. I chased my tail on that one for over a year.
Go with a fusible link. I got mine from a junkyard GM wiring loom.
8.30's @3400 lbs
[Re: Mike Swann]
#489287
10/06/09 12:31 AM
10/06/09 12:31 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
When I put my battery in the trunk I ran my main hot feed from the battery on a 10 gauge wire right from the battery to my starter relay and I used a 60 amp cartridge type fuse for my fusible link. I have just all the stock items on my 63 and I added the Mopar electronic ign , electric fuel pump and the electric fan that I just added a few months ago. Other then that it is just a stock 63 wire harness setup. I use a stock 55 amp alternator and everything has worked fine since 2006 when I go it on the road. I carry an extra 60 amp cartridge type fuse just in case but have never needed it. Ron
[Re: Cab_Burge]
#489289
10/06/09 01:55 AM
10/06/09 01:55 AM
383man
Balt. Md
How many amps does the starter, electric fuel, water pump, fan and ignition draw when all of them are on? Find that out and add a safe margin like 25 amps or a little more
Think you may want to eliminate the starter from that circuit. Ron
[Re: Mike Swann]
#489292
10/06/09 12:18 PM
10/06/09 12:18 PM
383man
Balt. Md
FYI, 10 awg is rated for 35a. You'll never get to 60a, except in SC condition.
The factory used 10 gauge alot on the older cars (60's & 70's) alt wires to the amp meter and battery. Ron
