408 intake /carb help #488543
10/05/09 06:58 AM
10/05/09 06:58 AM
@ the shop
E
E-85 408 DART Offline OP
E
@ the shop
building a 408 street/strip motor. short block is at machine shop & edelbrock heads are on there way to ryanjfor stage 2. diamond pistons 10.8, cam is hughes 4248 solid (.543/.563 242/248) 4:10 gear ,4speed,3300#(already have torker 2 and 750dp off old motor )shift point 6300,6500?? tti step headers . neeed intake and carb ??thanks
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: 408 intake /carb help [Re: E-85 408 DART] #488544
10/05/09 09:07 AM
10/05/09 09:07 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
If Ryans doin the heads, he will be the best shot on the right intake system advice + he has dynoed a ton of small blocks <takes out a lot of guess work>
Re: 408 intake /carb help [Re: emarine01] #488545
10/05/09 10:30 AM
10/05/09 10:30 AM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Curator at Adams County Speed Shop
Re: 408 intake /carb help [Re: E-85 408 DART] #488546
10/05/09 10:37 AM
10/05/09 10:37 AM
Az
Crizila Offline
Crizila  Offline
Az
Carbs ok. I'd stick a port matched Victor 340 Junior under it.
Fastest 300
Re: 408 intake /carb help [Re: E-85 408 DART] #488547
10/05/09 10:46 PM
10/05/09 10:46 PM
Iowa
Rodder Offline
Rodder  Offline
Iowa
I run almost the same set up with an automatic. I run a edelbrock RPM airgap to help with the heavy car. I also run a 750 double pumper that was worked by the carb shop to flow 830cfm. It likes more carb
and I have run a regular 850 on it. It really likes the more top end air but I have trouble getting it to idle very well with that 850. The air gap seems to run well with it I shift at 6 or 6200. My 68 cuda runs 7.01 at 96.5 in the 8th.
Re: 408 intake /carb help [Re: Rodder] #488548
10/05/09 11:00 PM
10/05/09 11:00 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
vic jr and a 950 on mine,
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 408 intake /carb help [Re: Stroker Scamp] #488549
10/05/09 11:48 PM
10/05/09 11:48 PM
@ the shop
E
E
@ the shop
i've never seen a victor jr ,anybody have a pic .is the jr the same as the victor 340 or is it somewhere between the torker 2 and the victor 340
Re: 408 intake /carb help [Re: E-85 408 DART] #488550
10/05/09 11:52 PM
10/05/09 11:52 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the victor is sometimes referred to victor jr...now that there is a super victor.
Tony
70 AARCuda Vitamin C
Re: 408 intake /carb help [Re: Crizila] #488551
10/06/09 06:37 AM
10/06/09 06:37 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We run one on a 416 with a 950 carb and it runs strong mid 11's on pump gas...
Re: 408 intake /carb help [Re: Stroker Scamp] #488552
10/06/09 06:52 AM
10/06/09 06:52 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Ran that on a previous SB stroker.
Re: 408 intake /carb help [Re: E-85 408 DART] #488553
10/06/09 01:38 PM
10/06/09 01:38 PM
owt west
Thread Ender1 Offline
owt west
look at the post above yours at the victor intake .
Re: 408 intake /carb help [Re: E-85 408 DART] #488554
10/06/09 03:18 PM
10/06/09 03:18 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A Weaind X-Celerator would not be a bad choice on you're motor. I have a Victor with a 950HP on my 408, fully ported Edelbrocks, 10.9- 1 with amost 20* duration at .050 though. It's gone 6.74 (1/8) spinning. In a 3300# Dart.
I think you're cam will be done at 6400 in a 400" motor. My 340 had a Hughes 3742 hydraulic, it liked to be shifted at 6200, it ran no quicker shifting any higher.
