70 E body dashpad removal #488105
10/04/09 03:59 PM
10/04/09 03:59 PM
L.I. N.Y. Hemi Street
HemiGreg Offline OP
HemiGreg  Offline OP
hey guys, im temp swapping my cudas dashpad for its rresoration and want to know the best/easiest way to get it out while the dash palel radio etc is still in place.
ideas meathods. let them fly.
thanks
Re: 70 E body dashpad removal [Re: HemiGreg] #488106
10/04/09 04:05 PM
10/04/09 04:05 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Greg
I've worked on a lot of E bodys and changed a lot of dash pads.
You can save yourself a LOT of cursing, a LOT of skinned knuckles if you just remove the dash assembly as a whole. Take it in the workshop and change the pad on the bench.
In order to get at the 12 nuts holding the pad on, you'll have to dismantle most of the dash anyways...
Trust me, you can remove the assembly in under 20 mins.
CHECK OUT MY NEW WEB SITE !
Re: 70 E body dashpad removal [Re: anlauto] #488107
10/04/09 04:13 PM
10/04/09 04:13 PM
HemiGreg Offline OP
HemiGreg  Offline OP
alan,
cant do it that way. pad has got to go out for months and im not taking whole thong in/out 4 times and keeping it drivable within the hour.
a picture of the nut locations would be great,
Ill get my niece with tiny hands and some flex joints to squeeze in.
Re: 70 E body dashpad removal [Re: HemiGreg] #488108
10/04/09 04:37 PM
10/04/09 04:37 PM
anlauto Offline
anlauto  Offline
Ok...Start by removing the glove box liner...the ash tray holder, the light bar, the instruments. You'll find three along the forward edge above the glove box, three behind the light bar and four along the back edge by the windshield and two more hiding somewhere I can't remember right now...
Re: 70 E body dashpad removal [Re: anlauto] #488109
10/04/09 05:01 PM
10/04/09 05:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 70 E body dashpad removal [Re: anlauto] #488110
10/04/09 07:31 PM
10/04/09 07:31 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Hey anlauto, Please tell me how to remove the whole assembly that quickly. I have a 74 barracuda.
Re: 70 E body dashpad removal [Re: cudabitten] #488111
10/04/09 08:15 PM
10/04/09 08:15 PM
anlauto Offline
anlauto  Offline
1)Open Hood
2)Remove four plugged wire harnesses from bulk head
3)Remove two nuts holding bulkhead in place
4)Open doors
5)Remove A piller trim and associated trim
6)Remove Kick Panels and associated trim
7)Unplug both door jamb light switches
8)Unplug E Brake warning wire
9)Unplug tail light harness
10)Unplug dimmer Switch
11)Reach up and unplug heater box
12)Unplug console light
13)Disconnect antenna
14)At the heater control, disconnect both heater cables
15)Unplug both steering coloumn harnesses
16)Unplug brake pedal switch, both wires
17)Undo both vent cables and let them hang
18)Remove 3 steering column bolts at firewall
19)Remove to nuts on steering column at the dash
20)Lower column and allow to hang
21)Remove 4 bolts at windshield using a 1/4 drive flex
22)Remove 2 bolts at door pillars
23)Prepare for a heavy dash to fall on your lap
24)Yell to wife for help
25) Have a cold beer, you're done
See 25 easy steps....It sounds like a lot, but with the dash assembly out and on the bench you can do a hundred things that you can't easily do in the car....Most important: INSPECT ALL THE WIRING
Re: 70 E body dashpad removal [Re: anlauto] #488112
10/05/09 12:12 AM
10/05/09 12:12 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
OK, I am going to save this post as I have been thinking of taking mine out as well, but I was a bit afraid. If anyone has any tutorial picks of removing the assembly would be great. And not to hijack from the poster, picks of the dash pad removal would be nice for him too.
Re: 70 E body dashpad removal [Re: moparmojo] #488113
10/05/09 02:10 AM
10/05/09 02:10 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
26 - Disconnect speedometer cable.
Re: 70 E body dashpad removal [Re: Snoopy] #488114
10/05/09 02:44 AM
10/05/09 02:44 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That one is always tough with the dash sitting in your lap...
Re: 70 E body dashpad removal [Re: Snoopy] #488115
10/05/09 05:34 AM
10/05/09 05:34 AM
anlauto Offline
anlauto  Offline
Dam It...I knew it wasn't Miller time yet!
After typing that responce for 25mins...I knew there would be one thing I forgot....Thanks Snoop!
Re: 70 E body dashpad removal [Re: anlauto] #488116
10/05/09 09:05 AM
10/05/09 09:05 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
My advice is to buy a core on ebag or craigslist or on Moparts. Send it to be rebuilt. Then take the dash all apart when the new one shows up.
It solves several problems.
1 Your VIN tag is not detatched from the your car for a long period of time.
2 Stuff gets lost when it is apart for sometime no matter how well you try to keep track of it.
3 Remembering how to put it back together and how the harness wires are routed, etc is easier. (Especially for guys like me with CRS)
When you are done, sell the core to another guy so he can do the same.
It worked well for me except I still have a core and have not had time to sell it
Craig
Re: 70 E body dashpad removal [Re: denfireguy] #488117
11/04/09 10:04 PM
11/04/09 10:04 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Swapped out my dash pad today, was not hard at all,done in 5 hours..amazing the dirt and stuff under there..cleaning was the tough part...can't see putting it all back without detailing everything..
Re: 70 E body dashpad removal [Re: AARCONV] #488118
11/04/09 10:10 PM
11/04/09 10:10 PM
anlauto Offline
anlauto  Offline
Well? Did you remove the dash as a unit, or just remove the pad while in the car?
Inquiring minds want to know?
Re: 70 E body dashpad removal [Re: anlauto] #488119
11/04/09 10:33 PM
11/04/09 10:33 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
just the pad..3/8 swivel socket in a 1/4 drive works wonders...1 screw on each side of the dash pad,1 on the right of the radio,remove left lower dash panel,lower steering column,remove left dash panel assy and unplug, remove light panel above cluster ,remove center bezel, remove cluster and let it hang, remove glove box door and compartment box,remove ash tray and ash tray housing that has the cigar lighter...remove 10 pal nuts holding pad to metal frame..remove both pillar panels...lift up and away...tough part..touching the vin plate....grinded the rivet off on the back, used a punch to punch the rosette rivets out,replaced with nos ones..made sure to clock them like the old ones so they look like they were not removed...tough part now over...time for detailing,upgrading speakers and so on...hope this helps you folks...
Re: 70 E body dashpad removal [Re: anlauto] #488120
11/05/09 06:59 PM
11/05/09 06:59 PM
Third Stone from the Sun
Scotts72Rallye Offline
1)Open Hood
4)Open doors
It would be great to have this in the tech archives. With 26 - Disconnect speedometer cable added also.
Scott
1972 Dodge Challenger Rallye
UNDER CONSTRUCTION
Re: 70 E body dashpad removal [Re: anlauto] #488121
11/05/09 07:27 PM
11/05/09 07:27 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Come on Alan, with any automotive repair, everyone knows the first thing you do is disconnect the battery
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 70 E body dashpad removal [Re: mopargem] #488122
11/27/11 12:27 AM
11/27/11 12:27 AM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
Looking to pull out my dash. Good thread.
I am going to use these steps and see how it goes...
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: 70 E body dashpad removal [Re: Scotts72Rallye] #488123
11/27/11 01:17 PM
11/27/11 01:17 PM
Alberta
rustbuckett68 Online content
rustbuckett68  Online Content
Alberta
Taking the seats out is a lot easier on the back and associated body parts, and doesn't take that long.
Re: 70 E body dashpad removal [Re: rustbuckett68] #488124
11/27/11 02:16 PM
11/27/11 02:16 PM
NM
74fish Offline
74fish  Offline
NM
