70 E body dashpad removal
#488105
10/04/09 03:59 PM
10/04/09 03:59 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
hey guys, im temp swapping my cudas dashpad for its rresoration and want to know the best/easiest way to get it out while the dash palel radio etc is still in place. ideas meathods. let them fly. thanks
Re: 70 E body dashpad removal
[Re: HemiGreg]
#488106
10/04/09 04:05 PM
10/04/09 04:05 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Greg I've worked on a lot of E bodys and changed a lot of dash pads.
You can save yourself a LOT of cursing, a LOT of skinned knuckles if you just remove the dash assembly as a whole. Take it in the workshop and change the pad on the bench.
In order to get at the 12 nuts holding the pad on, you'll have to dismantle most of the dash anyways...
Trust me, you can remove the assembly in under 20 mins.
CHECK OUT MY NEW WEB SITE !
[Re: anlauto]
#488107
10/04/09 04:13 PM
10/04/09 04:13 PM
HemiGreg
alan, cant do it that way. pad has got to go out for months and im not taking whole thong in/out 4 times and keeping it drivable within the hour. a picture of the nut locations would be great, Ill get my niece with tiny hands and some flex joints to squeeze in.
[Re: HemiGreg]
#488108
10/04/09 04:37 PM
10/04/09 04:37 PM
anlauto
Ok...Start by removing the glove box liner...the ash tray holder, the light bar, the instruments. You'll find three along the forward edge above the glove box, three behind the light bar and four along the back edge by the windshield and two more hiding somewhere I can't remember right now...
[Re: Snoopy]
#488114
10/05/09 02:44 AM
10/05/09 02:44 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
26 - Disconnect speedometer cable.
That one is always tough with the dash sitting in your lap...
[Re: anlauto]
#488116
10/05/09 09:05 AM
10/05/09 09:05 AM
Posts: 1,822 Colorado
denfireguy
Colorado
My advice is to buy a core on ebag or craigslist or on Moparts. Send it to be rebuilt. Then take the dash all apart when the new one shows up. It solves several problems. 1 Your VIN tag is not detatched from the your car for a long period of time. 2 Stuff gets lost when it is apart for sometime no matter how well you try to keep track of it. 3 Remembering how to put it back together and how the harness wires are routed, etc is easier. (Especially for guys like me with CRS) When you are done, sell the core to another guy so he can do the same. It worked well for me except I still have a core and have not had time to sell it Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: anlauto]
#488119
11/04/09 10:33 PM
11/04/09 10:33 PM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
just the pad..3/8 swivel socket in a 1/4 drive works wonders...1 screw on each side of the dash pad,1 on the right of the radio,remove left lower dash panel,lower steering column,remove left dash panel assy and unplug, remove light panel above cluster ,remove center bezel, remove cluster and let it hang, remove glove box door and compartment box,remove ash tray and ash tray housing that has the cigar lighter...remove 10 pal nuts holding pad to metal frame..remove both pillar panels...lift up and away...tough part..touching the vin plate....grinded the rivet off on the back, used a punch to punch the rosette rivets out,replaced with nos ones..made sure to clock them like the old ones so they look like they were not removed...tough part now over...time for detailing,upgrading speakers and so on...hope this helps you folks...
[Re: mopargem]
#488122
11/27/11 12:27 AM
11/27/11 12:27 AM
Posts: 297 Oklahoma
TinCuda
Oklahoma
Looking to pull out my dash. Good thread.
I am going to use these steps and see how it goes...
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
[Re: rustbuckett68]
#488124
11/27/11 02:16 PM
11/27/11 02:16 PM
Posts: 637 NM
74fish
NM
[Re: 74fish]
#488125
11/27/11 04:20 PM
11/27/11 04:20 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
You dont have to remove the bolts on the sides/kickpanels, just loosen them up and the dash will swivel on them Also removing the steering wheel will give you more room to maneuver the dash out.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
