Is 3" exhaust too much? #487052
10/03/09 05:25 PM
10/03/09 05:25 PM
Grand Forks, ND
cougar_cat_25 Offline OP
Grand Forks, ND
Looking to do up exhaust for a 440 that is mildly built up (about 400 hp). Whats your opinions, 3" or 2.5"?
Re: Is 3" exhaust too much? [Re: cougar_cat_25] #487053
10/03/09 05:31 PM
10/03/09 05:31 PM
Kirkland, Washington
Pacnorthcuda Offline
You don't need a 3" system to support 400hp.
Big pipes also drone more often than smaller.
...that said, I always thought a 2.75" system might be just right for so many applications.
Re: Is 3" exhaust too much? [Re: Pacnorthcuda] #487054
10/03/09 05:40 PM
10/03/09 05:40 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
3" will work real good.
Re: Is 3" exhaust too much? [Re: Dodgem] #487055
10/03/09 05:47 PM
10/03/09 05:47 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
A well executed 3" with an x-pipe AND tailpipes w/ muffler of your choice will allow room to grow when you want more than 400 hp....and you know you will want more!
Re: Is 3" exhaust too much? [Re: Dodgem] #487056
10/03/09 05:50 PM
10/03/09 05:50 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
My brother had 2.5" and went with 3" when he still had the 350 in his olds. It ran in the low 14's - high 13's most of the time. While the change didn't provide a huge power increase, the engine did seem to rev more freely, and it stopped blowing collector gaskets out where the tubing size transitioned from the 3" collector to the 2.5" exhaust pipe.
And yes 3" equals more noise vs 2.5" pipe. Depending on where you live the cops might take an interest in the sound making capacity of your ride.
Re: Is 3" exhaust too much? [Re: cougar_cat_25] #487057
10/03/09 05:52 PM
10/03/09 05:52 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
IMO 3" isn't needed, unless you plan to up-power the motor at some point.
Ride eternal, shiny and chrome
Re: Is 3" exhaust too much? [Re: DirectSubjection] #487058
10/03/09 06:23 PM
10/03/09 06:23 PM
I think anytime a header collector reducer is constricting the flow that power is being left on the table. A 3" system as said is much louder & correct muffs, an X pipe and resonators downstream would be mandatory.
Re: Is 3" exhaust too much? [Re: RapidRobert] #487059
10/03/09 06:27 PM
10/03/09 06:27 PM
East Windsor, CT
CFster Offline
super street
CFster  Offline
super street
East Windsor, CT
Had a 3" TTI H-pipe system and it was too freeking loud (as in drone). Changed to a 2.5" X-pipe system and it seems to have more low end torque as well.
Re: Is 3" exhaust too much? [Re: CFster] #487060
10/03/09 06:59 PM
10/03/09 06:59 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Colin, Love the car! Nice color combo, too.
Re: Is 3" exhaust too much? [Re: 64Post] #487061
10/03/09 07:11 PM
10/03/09 07:11 PM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
Aren't the F.A.S.T. cars using 2.5"? Pretty sure and they are in the 10's. If that's quick enough for you, stay with the 2.5".
Re: Is 3" exhaust too much? [Re: Intense RT Dan] #487062
10/03/09 07:25 PM
10/03/09 07:25 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Well yes they are because the rules dictate 2.5". Would they be faster with 3"??? Dunnno.
All I know is I put a 3" TTI sytem on my 71 cuda and it was very loud.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Is 3" exhaust too much? [Re: 64Post] #487063
10/03/09 07:26 PM
10/03/09 07:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I was about to comment about how good your 64 looks & saw 64Post had beaten me to it.. Good lookin car, the color & wheel choice both work well..
Re: Is 3" exhaust too much? [Re: 1_WILD_RT] #487064
10/03/09 07:33 PM
10/03/09 07:33 PM
East Windsor, CT
CFster Offline
super street
CFster  Offline
super street
East Windsor, CT
Thanks.
Re: Is 3" exhaust too much? [Re: cougar_cat_25] #487065
10/03/09 07:45 PM
10/03/09 07:45 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I think that 2.5" is plenty for a 400 hp engine. It should be quieter, have less drone and package better than 3". Also the extra velocity and heat in the exhaust gas should help keep the exhaust from rusting out from condensation, without being too restrictive. And many mufflers that have 3" in/outlets actually are 2.5" cores with the tubes swedged out, and don't really flow any more.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Is 3" exhaust too much? [Re: CFster] #487066
10/03/09 07:54 PM
10/03/09 07:54 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Hmmm...
Ideally, you would run open exhaust with optimized length collectors. Generally speaking, the less restrictive the system, the better.
Sometimes Low-end torque is slightly improved by a more restrictive system. There are systems I have read about the purportedly produce more power with X-Pipes and optimized, tuned mufflers, etc.
Still, less restrictive is typically the better way to go.
I own a '79 Jeep CJ5 with AMC 304 V8. I run 3-inch pipes and Dynomax Mufflers on it. It's not quiet, but not overly loud either.
I also own a '71 Charger. When I upgraded from 2 1/2-inch to 3 1/2-inch exhaust on the 440 in it, 1/4-mile ET performance improved by 7/10-second.
Re: Is 3" exhaust too much? [Re: D_C] #487067
10/03/09 08:01 PM
10/03/09 08:01 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I'm happy with mine.
Re: Is 3" exhaust too much? [Re: Evil Spirit] #487068
10/03/09 08:31 PM
10/03/09 08:31 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Here is a page from Magnaflows web site. One thing to consider also is the difference in mandrel bends and the typical exhaust shop bends that have the wrinkles in the bends. A 3" system that has kinks and wrinkles in the bends will not outflow a good mandrel bent 2.5" system.
5523028-MagnaFlow.doc (123 downloads)
Re: Is 3" exhaust too much? [Re: Evil Spirit] #487069
10/03/09 08:55 PM
10/03/09 08:55 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
On my 512 challenger motor I have 2" TTI headers and 3" pipe into flowmaster 40's that dump just before the rearend. My neighbor complained saying that when I idle my car it vibrates stuff off of his walls in his house 75 feet away. If he wasn't such a jerk I would care but I think he needs to insulate his house better. My other 4 neighbors say they can hear it but it doesn't bother them they love the way it sounds. I haven't been pulled over for it yet but I know I will after all I live in Idaho. In Idaho if it's fun or free it's illegal.
Re: Is 3" exhaust too much? [Re: Boise Chall] #487070
10/03/09 09:22 PM
10/03/09 09:22 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I'm gonna go out on a limb here and specutate that you are making more than the 400 HP that the original poster asked about
Re: Is 3" exhaust too much? [Re: cougar_cat_25] #487071
10/03/09 11:26 PM
10/03/09 11:26 PM
Grand Forks, ND
Grand Forks, ND
I'd just hate to mess up this engine by over heating valves and so on. You guys are right about the horse power tho, I haven't upgraded the intake, carb or the heads so I do have room to grow. However, it's a street car and I'd like to build it to be durable.
